smoke & boost
smoke & boost
ok fellas i have question i have my fuel pin turned, +2 full fuel, +1 or so on the smoke, and the afc maxed <i think if the afc is the gear that fuel fuel pin goes in> and i only smoke when i floor it, it blows a good amount but it doesent haze at all, even under load, and it doesent blow constant, only a big 'ole poof when i nail it? does anyone know why, can i elinimate the cloud down to a constant haze? i'd like a little bit under low and high boost conditions <no boost guage by the way> but not a huge cloud when i floor it! thanks
You could do what I did
Take the AFC spring out!! Lots of smoke and a small amount of haze in 5th. 4th is really hazy but I almost have it floored!
From what I can tell, the pin spring is there to provide resistance. Taking away all resistance results in minimum airflow=Lots of smoke!
Jon
Jon
ill try the smoke screw, i love smoke a lot but i love fuel milegae more, ill back the smoke screw out 1 or 2 turns, i think the pin shaving and washer shaving might help, and the 3200rpm spring will proab help 2! thanks
Pulling the AFC spring may gain smoke, but I've found that it also makes the turbo spool up a little slower.
Also 93beater, you should have some gauges in before you fool around with the IP
I just filled up this afternoon. With the spring gone and towing my buddy outta the field in 1st, I got 16.2 mpg. That is pretty good I think.
I took the spring out before the last fill-up.
Jon
I took the spring out before the last fill-up.Jon
i have a pyro being installed super soon, and i dont drive it real hard or pull much untill then, what other guages am i going to need mainly the maditory ones, b/c im broke as a bad joke, and im not gonig to pull the spring, my main goal is to reduce the smoke at high boost levels and even it out thru all low and high boost levels but only a very little ammoutn of it!
Let me get this straight, you get a big poof of smoke off the line, then it clears up? That is what you want, or are you wanting some haze all the time? I can fix you up with that, too.
Try backing out your AFC starwheel til it is level with the top of the well. Also, make sure your "smoke screw" is backed out, too. I have both mine backed out, and still get smoke til the turbo spools. If I hit it at about 1800 or above, i dont get much smoke.
Daniel
Daniel
Daniel
Daniel
jmccart
Oct 2, 2007 12:17 PM
D.Wiggs
Jan 4, 2007 04:24 PM
04ctd
26
Sep 25, 2006 09:47 PM
Mark Hodowanec
Feb 26, 2006 08:35 PM
