slow/hard cranking in morning
You should try looking at the contacts. Larry's super contacts (or something, forgot the name) will fix it right up.edit I found em,
did these on my dad's '97 and it solved his starting issues....
http://www.fostertruck.com/dodge/
Papecat
The old lead post terminals are far better than the screw terminals. The screw terminals will melt out of the battery on heavy loads leaving you stranded. Yes a good battery company can remelt the stud back into the battery as a repair but why chance it? I have had to replace many stud batteries because of this problem. BTW they will corrode too if you don't put grease on them.
The old lead post type will not corrode if you clean it upon installation and smear some grease all over it. Don't use those cheep bolt on battery cable terminals. Get the kind that solder on the cable and you will never have a problem.
Papecat
yeah i needed a jump sunday after i left my lights on
Then i checked my battery... its a measly 850cca... plugged it in last night and it started like it had been running all night
Also i've found that the soder terminals work better and last longer, the bolt-on one seem to loosen and corrode all the time... i've replaced a few hundred on golf carts i've repaired. Most of the time its just a gaggle of loose/corroded connections and batteries low on fluid.
Yes! All the help is greatly appriciated, and for $100 for a new proper sized battery, its good peace of mind to know it will work when i need it and its -20*C
