Signs of injection pump needing rebuild
Old Sep 21, 2007 | 09:22 AM
Jschlachta's Avatar
What are early signs of injection pump needing to be rebuilt other than leaks. been playing with fuel screw and notice that if I back it out two turns temps are close to the same and boost only drops a few psi Had dynoed a short while back and hit 250hp 670tq. Could a drop in hp (torque dropping at upper rpms) be a sign or a warn pump.
Old Sep 21, 2007 | 11:01 AM
JD730's Avatar
Idle dropping down when hot is the sign of a worn pump head and rotor. Mine is show the early signs of it right now, but the last dyno I went to I trailered another truck with my 93. 135 mile trip, unloaded and unhooked, I think the truck might have sat 10 minutes before getting strapped down and run. 367hp/847tq, on a trans with a bad front clutch.
What rpm is the hp/tq falling off, your throttle might not be adjusted to get the full affect of the 3200 rpm spring. Also, what lift pump are you running, I went to the low pressure piston lift pump and it made a huge difference from the original style one. But, I think I've out grown that one and will be looking for another alternative soon.
rattlebox01
May 28, 2010 05:00 PM
jeeptjstud
Nov 28, 2007 09:19 PM
gomerpile
May 6, 2007 10:20 AM
MJDiesel
Nov 29, 2005 04:56 PM
TE-44
19
Oct 29, 2003 04:23 PM
