Sheet Metal Screws or RivNuts for Cab Lights ???
Old Oct 7, 2023 | 06:12 PM
edwinsmith's Avatar
Originally Posted by Mexstan
Cougar is correct about the size of the hole and I should have mentioned this. If you try to install a Rivnut into a sloppy hole it is game over before you even start.
I hate sloppy holes.
Old Oct 7, 2023 | 08:43 PM
Mexstan's Avatar
Sigh .... there is ALWAYS someone >>>>>>>
Old Oct 8, 2023 | 04:17 AM
KRB's Avatar
KRB
Yea, and it seems like HE's always the someone...
Old Oct 8, 2023 | 01:28 PM
u2slow's Avatar
Example of the clips... for anyone not onboard with the rivnuts.
Old Oct 8, 2023 | 02:42 PM
BearKiller's Avatar
Thanks for the photo; I take it that is a Ford ?
Those clips are fine if one is replacing O.E.M. cab markers with identical ones; however, in my case, although my cab has the big center hole and the clips, the mount holes in the cab lights I am replacing with are miles away from the center opening and I would have to create two more rather large holes to accommodate the clips.
However, you have inadvertently given me an idea that I will share after I see whether it pans out.
Old Oct 8, 2023 | 06:52 PM
Mexstan's Avatar
Those clips look like Tinnerman nuts, commonly known as speed nuts. They are easier to use than Rivnuts and will hold the lights just fine.
Old Oct 9, 2023 | 05:48 AM
KRB's Avatar
KRB
I'm sure, like every thing else now days, they come in different thicknesses and materials, and thus quality?
Old Oct 9, 2023 | 09:02 AM
cougar's Avatar
Though frequently used on aircraft, I was never a fan of Tinnerman's. Had way too many of them fail in one way or another. I'd rather go through the misery of installing nut plates through a small hole.
Old Oct 9, 2023 | 12:40 PM
rustydiesel's Avatar
I generally avoid cheap aluminum nuts which are soft and react with stainless screws.
I have had good luck with the Lawson brand of blind rivet nuts (lawsonproducts.com), which are plated and have ridges on the barrel which bite into the underside of the sheet metal. I also use stainless riv nuts for exterior applications. Ditto with previous poster re anti-seize on the screw threads.
Rushman
Aug 6, 2012 09:23 AM
DodgenIt
Jan 14, 2010 11:00 PM
Berak
17
Apr 25, 2009 11:42 AM
SolidJunkMM
Oct 29, 2008 08:53 AM
rjm022
Sep 12, 2006 05:19 PM
