Safe Boost on 1st Gen
Old May 6, 2004 | 08:39 PM
bigred496's Avatar
i am about ready to get a 16cm housing, but i am wondering what a safe boost level is for my truck. already i can get to 33, it doesnt stay there very long, and with the addition of a smaller housing i know it should get more boost. what is the highest i can go before i should start to worry.
Old May 6, 2004 | 08:52 PM
nascar mark's Avatar
On average 45psi, but some head gaskets have gone at less than 20 and some of us have pushed 50+ without losing a stock head gasket. 45+ its just a matter of time.
Old May 6, 2004 | 10:49 PM
Stomp's Avatar
Oh I guess I should turn mine down again. I am currently running mine at 45psi.
No problems yet??????????? Knock on wood.
Stomp
Old May 7, 2004 | 10:02 AM
frostie's Avatar
This winter I was seeing 41 PSI regularly. It is warming up now and Im around 39 PSI. I have 265 K miles, no problems here.
Old May 10, 2004 | 09:39 AM
furious70's Avatar
where does the H1C get out of it's map though? Stomp and frostie have big turbos....
Old May 10, 2004 | 09:22 PM
Stomp's Avatar
32 or 36 cant remember, but I believe it is 32. maybe someone else can answer for sure.
Stomp
Old May 11, 2004 | 05:25 PM
bigred496's Avatar
does that mean i have to turn mine down, i currently have 33 psi max, thats with my foot buried and it only holds for a few seconds
Old May 11, 2004 | 06:24 PM
Lil Dog's Avatar
No, you don't have to turn it down.. After the 32# mark you start to have increases in EGT due to the drive pressure (pressure in the exhaust manifold) going up without a proportionate increase in boost. If you keep an eye glued to the EGT you will notice a nice steady climb then once you peak the boost out over 32ish psi, it goes up fairly quickly.
Typically if you have alot more fuel than turbo, its time to look at a different turbocharger.
J-eh
Old May 12, 2004 | 08:28 AM
furious70's Avatar
no, but the net result may be you may not really make any more power with more boost, and you might actually make about the same power with a few less psi
Old May 12, 2004 | 07:48 PM
bigred496's Avatar
will the addition of a turbine housing and bhaf have a more positive or negative overall effect, right now i still have the stock intake and 18cm housing
Old May 12, 2004 | 07:55 PM
Neither one will lower your boost any. The BHAF may help lower your EGT's, and if most of your driving is in local traffic the 16 cm housing will make the truck more fun to drive. Sounds like you've got a strong runner already.
EDIT: Have you thought about getting a wastegated housing instead of the 16?
Old May 13, 2004 | 12:50 AM
bigred496's Avatar
i actually saw a wastegated hx35 for sale and i was wondering how this would do on my truck, i plan on adding injectors in the future and also an intercooler, would the hx35 off of a 2nd gen or 3rd gen be compatible with mine, and if so could i just switch the housing to whatever the recommended is for that turbo?
Old May 13, 2004 | 06:08 PM
An HX-35 is an excellent swap. The older ones off 12 valve trucks will bolt right up, the newer ones have the exhaust elbow cast into the backplate so you'll need a different backplate or housing. And yes, all the housings that work with your H1C will work with the HX-35. The 12 cm housing that comes with the HX-35 is an excellent choice for a truck that is driven in traffic, spool-up is nearly instant. I love mine!
Old May 13, 2004 | 06:29 PM
bigred496's Avatar
would you recommend i go with the waste gated or non wastegated version. im trying to save myself the money of a new housing if i can just get a different turbo, so i am asking as many questions as i can.
Old May 13, 2004 | 06:47 PM
With the way your truck is set up right now, a stock HX-35 would be great. The stock housing is a 12 cm wastegated, that will be fine for now. As you add more fuel, you may find that you need a bigger housing (14 or 16 cm) to keep the EGT down at high RPM. You should be able to get a good used HX-35 for around $300.
