Rusty drums
Rusty drums
I have been tracking down a moderate to severe shake or bounce in the rear of my truck I have replaced tranny mount with no success. I checked the u-joints,the outer wheel bearings,the tires are balanced. The only thing that has helped is the new shocks. It keeps the vibration from getting to bad and shaking me off the road. I took the tires off and ran it up to 40 and there was still a shake. I looked at the drums and noticed the edge of the drum was so rusty it was starting to come apart in chunks and one drum had a balancing weight and the other didn't. Could this cause a shake like an out of balance tire. Do all dually drums have a counter weight.
How well did you check the u-joints? Same thing happened to a friend of mine and when he described it to me on the phone I said u-joints and he insisted they where fine. I said they were probably starting to seize up.
I just did the eyeball and shake them test. They are probably going to get replaced Saturday when I do the drums and depending on the inner wheel bearings they might get replaced also.
snowmanx
05-23-2010 09:18 PM
asnowsquall
03-15-2009 06:59 PM
