Replace whole front end joints, bushing, seals etc.
Old May 26, 2011 | 02:21 PM
wmbthe4's Avatar
i own a 91.5 w250 dana 60f in the front. and would like to know what would i need to replace on the front end? kingpins, shocks, seals...since i gotta do pinion seals im think id rather just replace everything down there at one time and not have to mess with it again for years to come. so what are all that bushing, seals and bearings that are in the front end and u-joints. could someone give me a list of everything down there. and possibly pics too. thanks
Old May 26, 2011 | 02:34 PM
BILTIT's Avatar
http://www.pirate4x4.com/tech/billavista/60_front/
Old May 26, 2011 | 02:38 PM
maybe368's Avatar
These guys have kits that include everything you need. The king pin bushing kit has all the seals, except the inner wheel bearing grease seal. They sell the upper king pins with the tool also. The u-joints and tie rod ends should be replaced. The spring shackle bushings are next on my to do list, as well as new shocks and steering stabilizer...Mark
Old May 26, 2011 | 03:05 PM
BILTIT's Avatar
Alittle cheaper here:
https://www.4wdfactory.com/store/pro...in-Rebuild-Kit
Old May 27, 2011 | 04:38 PM
92'1stGen's Avatar
Check 4wd factory, quad4x4 is over priced. Unless your pinion seal is leaking like crazy then I wouldn't bother with it. Too much hassle, not enough reward. Running around the hubs should be unlocked anyway, meaning the front drive shaft won't be turning.
The most important stuff you'll need will be two king pin kits, two u-joints, two needle bearing kits, two wheel bearing kits, (mud slingers I wasnt sure about so I just bought them they were cheap), and if there's anything else I'm sure someone else will chime in. Good luck to ya.
ncj01
Apr 26, 2014 01:36 AM
fatpete
15
Nov 28, 2010 10:13 PM
Joe Diesel
23
Mar 25, 2008 07:39 AM
1320
Jul 23, 2006 05:00 PM
Dusty 96
0
Dec 1, 2002 07:01 PM
