Removing the vented cowl behind the hood
Old Jul 1, 2011 | 05:12 PM
Mike T.'s Avatar
Sorry, I don't know what you call that thing. I noticed that there are screws underneath the winshield weather stripping that seems to help hold it in place. Is the metal slotted under there or do I have to remove the weather strip and remove the screws?
Thanks
Old Jul 1, 2011 | 05:25 PM
maybe368's Avatar
Thanks
You have to removes the screws, but you should be able to hold the rubber back, if it isn't too dry and brittle...Mark
Old Jul 1, 2011 | 09:22 PM
Onemoparnut's Avatar
Mine is notched and slid right out with out removing the screws. BTW that piece is called the cowl panel.
Old Jul 1, 2011 | 11:26 PM
Remove your wiper arms, then the 8-10 screws on the front edge of the cowl panel, lift and remove.
Old Jul 2, 2011 | 07:57 AM
Mike T.'s Avatar
Thanks for the help.
Old Jul 2, 2011 | 08:13 AM
jimbo486's Avatar
Same here. All I had to do was remove wiper arms, squirters and the screws across the front edge (in the engine compartment) and slide the piece out.
Old Jul 2, 2011 | 04:41 PM
joeytechman's Avatar
I never even saw the other screws when I removed mine
GO 4LO
Nov 1, 2005 02:59 PM
DuaneWKKC
Oct 18, 2004 02:29 PM
Nov 12, 2003 10:08 PM
cumminsho2500
Sep 8, 2003 12:17 PM
Monty
Jan 15, 2003 07:21 PM
