Removing fuel filter nipple
Old Nov 3, 2013 | 10:21 AM
Rickcher's Avatar
What size nut do I need to run up onto the fuel filter nipple to remove it? I've tried various other methods and I don't want to trash the nipple because I'm not deleting the fuel heater, just replacing the o-ring. Also, has anyone else had trouble with the "search"? I haven't been able to get it to load for the past week. It may be my computer, just wanted to see if anyone else was having trouble. Thanks.
Old Nov 3, 2013 | 04:08 PM
maybe368's Avatar
IIRC, There is a slot in the threaded nipple that the fuel filter screws onto, just use a very big screw driver to thread the nipple out...Mark
Old Nov 3, 2013 | 04:29 PM
Several folks have used a blank chrysler key with the big head on it. Attach a vise grip to it, and youre good to go....
Old Nov 3, 2013 | 06:02 PM
MARF75's Avatar
I used a paddle or spade bit for drilling in wood. Fits nicely in the slot and has a 1/4" hex on the end to get a socket on!
Old Nov 3, 2013 | 06:28 PM
m-o-p-a-r's Avatar
That is exactly how I do it also!
Old Nov 3, 2013 | 06:37 PM
Rickcher's Avatar
That might work. I tried several things in that slot but it's on there pretty good and I started chewing the slot up. I read on here one time where someone threaded two metric nuts on it to lock them together and just threaded it off, but I couldn't find the thread. I'll try the spade bit. Thanks!
Old Nov 3, 2013 | 10:37 PM
Never thought of that...great idea!! I've used the key method before...worked OK.
Old Nov 3, 2013 | 10:45 PM
BearKiller's Avatar
Once in a while, the filter-stud is a hollow HEX, requiring a large metric Allen-wrench to remove it.
I have had a few just come screwing out with the filter.
Old Nov 4, 2013 | 11:14 AM
j_martin's Avatar
  • Overall Height 112.27 mm (4.42 in)
  • Largest OD 77.47 mm (3.05 in)
  • Thread Size M16 X 1.5-6H INT
hope it helps
Old Nov 5, 2013 | 05:43 PM
sshort's Avatar
what you need is called a drag link it is a screw driver on a half inch drive socket.
Old Nov 5, 2013 | 06:27 PM
mknittle's Avatar
A draglink socket is way too thick. At least mine is.
Old Nov 5, 2013 | 07:54 PM
209trucker's Avatar
I used a chisel to remove mine.
meangreen96
May 12, 2011 06:30 AM
RamW350 dually
Apr 21, 2010 07:39 AM
Ramrod90
Mar 3, 2009 07:20 PM
nitrousn
Aug 5, 2005 10:27 PM
nitrousn
Aug 1, 2005 09:59 PM
