Rear main seal repair
Old Nov 12, 2004 | 09:13 AM
92DIESEL's Avatar
Question Rear main seal repair
I've done some searching already but I value you guys opinion greatly so any help is appricated(spelling).
My rear main seal is leaking real bad(1 1/2-2 qts a day ).
I have made up my mind that I'm going to change the seal. I have on order (from cummins) rear seal with wear sleeve, cam O-ring, and that upside down U shaped gasket.
I would like to know if anyone else has done this job before and can give me any advice or hints to make this job easier, I will be doing it alone next weekend(11/20/04) and am a little worried
Thank you in advance, Michael
Old Nov 12, 2004 | 10:03 AM
RBJenn's Avatar
I Just did the job three days ago. Its real simple after you pull the trans and bell housing remove the clutch and flywheel ( real heavy) the seal is right behind. Drill two small holes in the old seal use slide hamer to knock it out clean things up and install new seal it should have a guide to slide it over the crank and an inttall ring to hammer it in the correct depth.
Old Nov 13, 2004 | 09:30 AM
92DIESEL's Avatar
Thanks for the info RBJenn, mine an auto so I shouldnt have the heavy flywheel
Hope I can do this by myself in 1 weekend- only form of transport and have to work on Monday
Thanks again, Michael
Old Nov 13, 2004 | 12:02 PM
RBJenn's Avatar
You should be able to it only took me seven hr after renting a transmission jack. an auto trans shouldnt be any harder.
ted_pulliam
Aug 4, 2010 11:33 AM
vj_M
Apr 26, 2009 02:00 PM
bnold
Jul 7, 2007 06:18 PM
okcummins
Dec 21, 2003 07:45 PM
Mostwanted
Sep 17, 2003 06:55 AM
