rear end gears
There should be a tag held on the rearend with two of the cover bolts.
The sticker on the hood should say too.
Pull cover and look at numbers on ring gear.
Otherwise you have to turn the driveshaft until the wheels rotate once and count turns of shaft. If only one wheel turns go two turns of the wheel. If you don't have a posi you are better off to leave one on the ground.
doorguy
06-08-2007 06:19 AM
badmrb
05-27-2005 05:48 PM
