Rear Diff assembly question
Old Mar 5, 2009 | 03:40 PM
flyingd's Avatar
I just put my rear diff back together. Had to replace the clutch pack.
The question is, should the spider "cross" move a little after assembly. It just moves a little.
Thanks
Old Mar 5, 2009 | 05:39 PM
By hand? It should be wedged in there pretty tight with new clutches.
Old Mar 5, 2009 | 05:48 PM
feveree40's Avatar
the new clutches should be crushing it in there real tight. When you bolted the carrier back together did you need to pull the last 1/8th inch together with the bolts?
Old Mar 5, 2009 | 06:41 PM
flyingd's Avatar
I did need to pull it the last 1/8th or so. But the spider that holds the gears is a little loose.
What did I do wrong
afate45
Jun 7, 2014 12:08 AM
mybajadodgeram
May 5, 2012 03:19 PM
CLS LLC
Aug 27, 2011 08:15 PM
banana
Dec 1, 2009 11:44 PM
Royboy Ft,Sask
Oct 22, 2006 02:25 AM
