rear brake issue
rear brake issue
I performed a rear axle brake job and when i bled the brake lines i get very little brake fluid and the pedal never drops. Is there a proportioning or metering valve in this system?
Yes, there is a proportioning valve, Dodge calls it a combination valve because it has the sender for the "brake" light on it. My 90 has it in the driver side frame rail, near the starter. Your 93 may be closer to master cylinder, but I am not sure of this. Do a search on bleeding and there is a ton of info on how to do it right...Mark
dan123dbl
Feb 13, 2015 05:47 PM
