raised the front end a little need u bolts
Old Nov 24, 2006 | 08:35 PM
Boatnik's Avatar
I finally got around to adding some leaves to my front springs today. It lifted the front about an inch and a half. It looks good and it drives good, so I am almost happy. The U bolts are too short . I don't have a full nut on any thing, even after removing the flat washers. Where might I find two 1/2 x 3 1/4 x 10 inch u bolts for the drivers side and one 1/2 x 4 x 10 inch u bolt for the passenger side? Two 9/16-18 grade 8 capscrews of proper length and lock washers took care of the studs. NAPA and Advance couldn't help. I think the original bolts are an alloy. They are harder than 1018 or A36. Most likely they might be A193-B7.
Old Nov 24, 2006 | 08:43 PM
G1625S's Avatar
I'd love to hear of a source for u-bolts as well, as I added the later style lift blocks in the rear and re-used the old u-bolts, which I hear is a nono....
Old Nov 24, 2006 | 08:48 PM
Ilikebikes's Avatar
Check around your area for spring manufacturers. When I put in my 2" fronts I had to get new ones made, and they ran me about $7 or 8 a pop.
Old Nov 24, 2006 | 08:51 PM
rlyons's Avatar
I had a set made while on a trip last summer in new Mexico at a spring shop, he did them in just a few minutes each. This was the shop. If you can't get them anywhere else give them a call, they were great to work with.
Hobbs Spring & Suspension Inc
(505) 393-3051
Old Nov 24, 2006 | 08:59 PM
broncobilly's Avatar
Wildhorses 4x4 (a Ford Early Bronco 4x4 supplier) sells some HD u bolt kits. I don't know if they are strictly for a Dana 44 axle? You might check out their web site at wildhorses4x4.com, and see what they have. I know alot of the Early Bronco crowd runs Dana 60 front axles. HTH!
Old Nov 24, 2006 | 09:13 PM
rustbucket's Avatar
go to ebay,and look under lift kits and parts. I found mine there,for 31.00 plus shiping.
Old Nov 24, 2006 | 09:29 PM
Boatnik's Avatar
I went there after trying to obtain them locally. Couldn't find any tha would fit. I even went to some of the "stores" and no luck. There is a trailer manufacture and retail center in Hampton, VA called Hibbard Iron Works. I will be dropping by there tomorrow. I have bought trailer items from them and thet have a high opinion of their products. $$$
Old Nov 24, 2006 | 09:37 PM
RATTLINRAM's Avatar
Boatnik,
Try calling Thurston Springs Service in Richmond. # 232-8981
Old Nov 24, 2006 | 09:47 PM
W900A's Avatar
Eaton Detroit Spring is a good resource. I started buying quite a few items from them as most of the local spring shops have disappeared in the last few years. Shipping springs gets a bit pricey, however I have been able to offset the cost some. They are great people to deal with both for OEM replacement parts or special custom made items.
just google Eaton Detroit Springs, I think they are the first hit listed.
Old Nov 24, 2006 | 11:30 PM
BearKiller's Avatar
Any of the off-road lift-kit companies, i.e. Rugged Trail, Superlift, Rancho, Burbank Spring, Etc., will have a vast selection of various u-bolt lengths/sizes.
These will be zinc-plated and hardened, for less money than un-hardened shop-made ones.
What is wrong with using old u-bolts??
I have used old u-bolts over on many applications with no ill effects that I ever noticed.
The only u-bolts that ever gave me problems were some I had custom bent and threaded at the local machine shop.
They kept stretching, actually gained a couple inches, before I got some good ones from a suspension lift company.
Old Nov 25, 2006 | 09:04 AM
EClancy's Avatar
do a search for stengel brothers u bolts. They make custom u bolts to order, and have tons of ready made sizes. great people to deal with, reasonable prices AND shipping
Old Nov 25, 2006 | 06:55 PM
DODGE 92's Avatar
springs
go to a local spring shop they have what you need
Don H
Jul 13, 2004 06:52 PM
dvp98.5
Jan 3, 2004 10:39 PM
Dieseldude4x4
Dec 21, 2003 10:00 PM
Bamboozal
Aug 19, 2003 03:15 PM
redramnc
Mar 18, 2003 03:35 PM
