question for those running 4:10 gears,fast?
Old Aug 12, 2009 | 07:43 PM
crewcabxlt's Avatar
planning to build another cummins powered ford crewcab for my wife this fall/winter. truck has 4:10 gears. going to run a 366 governor spring and 35" tires. nearest freeway is 40 miles away so it doesnt have to do 80 mph but i would like 70 +. i had a 1st gen with 4:10 ,s and a getrag,31" tires, stock governor spring, it would only do 65 max pedal to the floor. what are you guys running with 4:10,s to get some top end? i have other axles if i want to regear. truck in my sig has 3:54,s. this truck will have a 518 auto trans, aftermarket t/c. thanks for any responses.
Old Aug 12, 2009 | 07:57 PM
DNRCustoms's Avatar
4.10 gears and 35" tires with a unlocked converter I am at like 2250 at 70 mph. Locked up, I am at 1950rpm, but unless you have a 47rh upgrade you will be in the 2200 rpm range!!
Old Aug 12, 2009 | 08:17 PM
Richie O's Avatar
366 Spring Chicken
4.10's with an overdrive is about the same final ratio as a 3.08 truck with the 727 3 speed. You will have no issues. I have 4.10's in my 93 ( but with a rag ) and I can do 70 in 4th and about 95 in 5th.
Old Aug 13, 2009 | 12:14 AM
simplysmn's Avatar
my top speed with 39's was 85 with 410's
Old Aug 14, 2009 | 09:02 AM
crewcabxlt's Avatar
ok, thanks for replies, gonna try 4:10,s
Old Aug 14, 2009 | 03:55 PM
RollinCoalSmoke's Avatar
I have 4:10s with the A518 auto stock convertor with the GV od 4x4 stock tires and 96 98 max speed. Tach is not working so not sure of the rpm's but it sounds tight with the stock gov spring.
Old Aug 14, 2009 | 04:38 PM
G1625S's Avatar
Gonna be just a driver for the little lady? If that's the case, 4.10's would be a waste. 3.54's or shallower for good on-highway fuel economy. I'm running 3.54's and 315's on my 2nd gen. Thought I'd hate it, but 1750@65 and 21 mpg (on highway) is real nice
Jim Lane
Dec 7, 2015 09:16 PM
EdmontonCanada
37
Dec 9, 2009 03:18 AM
trik396
Mar 14, 2007 07:57 AM
93beater
Feb 28, 2007 09:28 AM
walexa
30
Apr 8, 2005 10:26 AM
