Pump leak fixable?
Old Apr 9, 2008 | 09:49 AM
chsaverline's Avatar
Pump leak fixable?
I have a 93 with 268k miles. My injection pump has formed a leak from the throttle lever. Is there a way to fix it without replacing the pump. I dont know if the pump is original or has ever been replaced. If I do need to replace it where is the cheapest place to buy one. My local shop wants 1k to rebuild it. Seems a little high. Thanks Chris
Old Apr 9, 2008 | 10:21 AM
BigIron70's Avatar
Cummins Guru
There is a Safety Recall #605 -- Diesel Fuel Injection Pump. I would check dealer and see if has been done. If not, there is no expiration on recalls. Fuel injection pump replacement is only necessary for pumps manufactured between March and September, 1991 (date codes 163 through 169),Pumps having an infinity symbol (¥) on either the pump data plate or the Mopar Remanufactured Parts data tag have already been repaired and therefore, do not require replacement.
Old Apr 9, 2008 | 12:04 PM
turboguy121's Avatar
this is a good thing to know good info
Old Apr 9, 2008 | 04:08 PM
The throttle shaft leak can be fixed with the pump still on the truck. Look in the sticky for info on installing a 3200 RPM spring, replacing that seal involves the same steps. You need a throttle shaft o-ring.
Get a 3200 RPM spring so you can install it while you're in there.
Old Apr 9, 2008 | 06:30 PM
91.5 beater's Avatar
How exactly do i find out if mine is a recall?
Old Apr 9, 2008 | 08:41 PM
BigIron70's Avatar
Cummins Guru
Recall #605
Old Apr 9, 2008 | 09:10 PM
Thanks, mine says 562 so so much for a new pump
bflood
Dec 29, 2019 06:05 AM
Valv
Mar 11, 2012 07:05 PM
andy45
Oct 15, 2009 12:59 PM
Bobcat698
Nov 21, 2005 09:19 PM
amartinson
0
May 4, 2003 01:55 PM
