To Pull Or To Drag
Old Jan 10, 2010 | 10:43 AM
RSWORDS's Avatar
Its alot eaiser for a 1st gen to be competitive drag racing then pulling...
Old Jan 10, 2010 | 11:46 AM
^ What he said. Light weight is a bonus in drag racing but a detriment in pulling. Of course, if you are pulling in a class that will let you hang weight where you want it, a 1st gen gives you more tuning options for a good hook...
Old Jan 10, 2010 | 12:12 PM
CaptainChrysler's Avatar
No dentures here.
A 1/2 ton won't have the good front axle you will need for pullin, or the bigger frame.
Old Jan 10, 2010 | 05:15 PM
Greed 93's Avatar
I have a 14 bolt rear and 60 for the front i dont understand the frame part a friend has a scout with a 655 indy motor with stock frame no worries as of yet. also his brother has a 70's f-100 2wd 600 plus inch ford factory trans and frame or is it just the first gen half ton frame thats to worry about/
thanks
Old Jan 10, 2010 | 08:10 PM
Sounds like you have the axles covered. If you plan on running suspension stops, I would beef up the frame over the rear axle. The 1/2 tons have a lighter frame that will probably twist a good bit with the VE's torque. Gassers run more rpm's and less TQ.
Old Jan 10, 2010 | 11:16 PM
Greed 93's Avatar
ok so if i box the frame above th axles i should be good.
Tree DR
MODTR #30
30
Sep 18, 2009 10:24 AM
coonhunter723
Competition / Pulls / OffRoad
Mar 31, 2008 11:00 AM
tristan21
Mar 14, 2008 12:27 AM
sledneck1
Feb 7, 2007 01:57 PM
