power needed!!??
ok fellas i have my full fuel about +2/3 turns in fuel pin grinded down smoke screw backed off and the star down a bit i have awesome power @ lower speeds but after about 40 mph i start to loose the smoke and still have some power but im wanting more, is there any quick and cheap solution to fix this?
we have a cummins store here in town not sure if they have 1 but ill call around, also i dont have hardly any time or experince so i can have my mechanic friend install it, what do u think as a professional a good price would be?
Check my sig...
The ricers I can't outrun - I smoke out.
Last 1/4 was officially 19.+ @ 69. Now I run that in 2nd on an uphill expressway on-ramp.
Go with the 3200 spring, and crank the power screw to run-away, then back off.
ok the only spring i found is 16 dollars proab aropund 25 with shipping and i also wanted my valves adjusted, my mechanic friend said he do both spring and adjust the valves for 150-200$ does this sound reasonable?
That doesn't sound too bad, but seriously you can do either of them yourself... the write ups that are in the sticky will walk you right throuh it. all you need for the valve adjust is feeler gague and torque wrench. Also try to find someone from the forum that is local, i'm sure they'd be able to help you save a few $$. Then that money can go into other mods... maybe injectors or HTTurbo upgrade....
