power door lock switch?
93 ext LE
Chasing an inoperative power lock switch on drivers door. Works from passenger side but not drivers. Question is; do I need to pull door panel to remove switches from panel or do they pop out like newer vehicles?
I searched with no luck.
Thanks
Thanks
Not sure if this will help you Krusty, but have a look anyway. It's from the Sticky in the 'Body' section. https://www.dieseltruckresource.com/...d.php?t=218946
Check the switch and see if it has come apart, When the plastic breaks they can become intermittent or not work at all.
They work by reversing the polarity to drive the motor actuators between lock and unlock.
Jim
Jim
I had a similar problem when the pass. side went out first then both. I pulled both switch panels first and they checked out OK. What I found was two wires in the loom from the body to the door - on the pass side - after repairing them all was and still is good. I would also check these looms on both sides.
Bob
Bob
Dynocon
Mar 4, 2008 08:32 PM
staarma
0
Oct 25, 2007 12:49 PM
AllonBlack
Jul 30, 2007 05:51 PM
xp8103
Jun 2, 2006 07:00 AM
mr T
21
Jun 1, 2005 08:48 AM
