Post your twin turbo pics!
Old Oct 7, 2009 | 04:51 PM
93Fury's Avatar
Anyone running a HX35 over a S400? We've been discussing putting twins on my truck and were pondering this setup. Any thoughts or objections?
Old Oct 7, 2009 | 08:52 PM
peobryant's Avatar
I have heard of two or three people using this set up and they really like it. Really fast spool up, and can handle a bit of power. I'm not positive if they were running it on a 1st Gen though...
Old Oct 7, 2009 | 10:07 PM
BC847's Avatar
1st Generation Admin
Originally Posted by RSWORDS
David, did you weld the lip on teh bottom of the cobra pipe for the v-band clamp or does it come stock like that?
PDR made it (welded).
Old Oct 7, 2009 | 10:16 PM
soggy's Avatar
I'm interested in seeing KTA's setup.
Old Oct 7, 2009 | 11:24 PM
schamran's Avatar
JAyers has an interesting setup.
https://www.dieseltruckresource.com/...hp?photo=38412
Old Oct 8, 2009 | 05:54 AM
sgreen3's Avatar
Man dont I feel like a ,lol I forgot all about that extra pipe plug in the filter housing.
Originally Posted by CaptainChrysler
I got lucky on the oil feed line. I was able to take everything with the turbo, oil line and fittings. The fitting from the 855 screwed right into the filter housing on the 5.9. You need a fitting that is 1/8" NPT male to whatever line you use. Make sure you use 3/8" line to feed it. Most people just get a hydraulic hose made.
On the drains, as long as both lines go downhill all the way to the nipple in the block, it should work fine. If it is too low, you will have to add a drain to the oil pan, above the normal oil level.
Found a pic:
Old Oct 8, 2009 | 05:57 AM
sgreen3's Avatar
So would any of you guys know were I could go and get info on that detroit turbo I have. Like specs and stuff or would any of you guys happen to know.
Old Oct 8, 2009 | 08:40 AM
RowJ's Avatar
Works great on a 2nd Gen.
RIP, at Source Automotive has sold the kits for this set up for yrs.
I've driven two with HX-35/S400 and they work as well as my BD twins. Run just as cool also...up to 600 hp and 65 psi boost.
RJ
Old Oct 8, 2009 | 11:16 AM
RonA's Avatar
Originally Posted by BC847
I run the HX35/40 hybrid over an HT3B . . .
It has an HX40 inlet so if you plan on running an HX35, you'll need a simple adaptor.
With some Scheid 6x.06 EDM and a maxed 12mm VE, yesterdays 8.23 1/8th mile pass had the EGT's no higher than 1500*F @ 55psig boost (with a ported head, cam, big IC, etc).
The 3b/40 over 3b setup works darn good, and your under the hood pics are outstanding. Nice work.
Old Oct 8, 2009 | 02:18 PM
Riflemanusmc's Avatar
Registered user
That turbo is off of either a 6v92 or a 8v92. If that is of any help to you.
Old Oct 8, 2009 | 05:25 PM
93Fury's Avatar
RJ
That's good to know, seem to be what I'm looking for. Plus I have an S400 and a 60mm HX35, so this winter I think I'll start the piping. Thanks for the pointing me toward Source, I'll give them a call for info.
Old Oct 10, 2009 | 12:32 PM
RSWORDS's Avatar
Thanks
wwm
Mar 13, 2009 12:30 PM
1974d2004x4
13
Oct 17, 2007 07:47 AM
VikingDiesel
116
Aug 2, 2006 05:50 PM
MR HYDROSEED
Nov 15, 2005 11:31 PM
BigBlackBeast05
Jul 24, 2005 09:47 PM
