Is it possible to do?>>>
The side cover gasket with the injection pump still on the motor?if so how is it done cause I need to do mine bad.....I'm leaking about 3quarts a week right now. I need some help only truck running an driving at the moment.please......I'm having to rebuilt the trans in my daully because the reverse band popped off. I let someone else rebuild it. I will be rebuilding the next one.....
I would say it is not possible, all you need to do is remove your injection pump with all the lines, vacuum/ steering pump and intercooler pipe if its in the way to get to the side of the block, then you have a straight shot at the side cover after you remove the sound insulating cover.
It seems like alot of work for the first timer but it can be done in an afternoon.
Also tag the injection lines before you remove them so you can return then in the proper order.
I always take lots of pictures when I work in case I have any doubts,
But I never do.
Jim
But I never do.
Jim
You can pull those injection lines without separating them. Come off in two groups of three. There is however a trick to putting them back on. You have to start with the top back line on the pump and tighten it first. Then install the back three lines and work your way around the pump clockwise. I've had my pump and injectors out so much lately i can swap injectors in less than 45 min and a pump in two.
Did you try and give the bolts a little snug up to buy time? I'm with the masses here not thinking it could be done with out pump removal, even if you did I'm guessing it would be so hard to get the gasket lined back up it would end up leaking worse than now.
I've messed with these truck a good bit but yet to take the pump an lines off of it . I've just been scared to take the pump off an not get it back together right. So I haven't messed with it. Is there anything special i need . I have all the parts is there anything else to do while I have this all apart? Do I need any special tools? Thanks for the help greatly appreciated. Thanks to u all. Is there anything I should watch out for?
John
John
AlpineRAM
Mar 10, 2003 05:47 PM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
