POD's and lack of smoke
Old May 18, 2008 | 08:55 PM
Stihl's Avatar
Okay I installed the POD's over the weekend and it bumped my idle down by about 200 RPM's, so I turned the Full Power Screw in one full turn to correct this. But still NO smoke, small puff of black soot at startup along with a puff when I hit the gas in neutral but this is all .. I realize smoke = unburnt fuel, but considering the fact that everyone says these puppies smoke I'm afraid I may have some engine problems? I can reach +30 boost on grades under no load, and I don't seem to have a whole lot of problem with power .. but my gas mileage sucks .. 12-14 ( fuel filter, air filter all clean ) Here's what my truck has ...
93 Intercooled 54k on motor and A/T trans ( cummins rebuild )
Dana 60/70 Stock G/R, 38" Toyo MT's
4 inch exhaust going to 5 inch straight stacks
Aftermarked fuel pump by Seattle Injectors
P.O.D.'s
Smoke screw in full
Starwheel in full then backed off two full turns
Fuel pin at "deepest" setting towards radiator
Full Power Screw turned 2+ full over stock
Is it possible something is wrong? Or should I just be happy that it's no freight train
Old May 19, 2008 | 02:36 AM
stackx2's Avatar
have you removed the spring out of the top of the diapham? that wont allow it to smoke until the turbo biulds boost. take that out and it should smoke pretty good
Old May 19, 2008 | 06:41 AM
Advance the timing.
Old May 19, 2008 | 09:17 AM
Jschlachta's Avatar
check to make sure the fuel pin is moving down, look for a wear mark on it. if there is no mark you may have a air leak to afc make sure the little air hose from the intake manifold to the afc has all connections tight. if there is a leak the afc will not sense boost and not increase fuel.
Old May 19, 2008 | 09:19 AM
Jschlachta's Avatar
with the stare wheel down and the settings you have you should be able to produce smoke. with my star wheel down it will smoke like crazy until the boost kicks in.
Old May 19, 2008 | 09:20 AM
Jschlachta's Avatar
also what turbo and exhaust housing are you running?
Old May 19, 2008 | 08:42 PM
Stihl's Avatar
Stock turbo + housing, seems this setup with my tweaks would produce more smoke not less
Fuel pin is moving .. or "was" moving at some point at least .. when I popped it out yesterday it had marks on it .. the pump is 2-3 months old.
Timing could probably be adjusted but wouldn't that decrease smoke, ie increase efficiency?
I'll try popping out the spring .. as long as my fuel pump wont fall apart without it
My boost also seems to kick in very easily .. I have a hard time accelerating old man style without hitting 3-5 psi I'm not sure if this is normal or not, the only other 1st gen's I've driven were without guages
hotrod929
Aug 30, 2009 10:48 PM
06dodgedrw
Dec 14, 2008 04:19 PM
92cummisw350le
Dec 9, 2007 09:14 PM
96_12V
Jul 25, 2006 11:42 PM
Geico266
Jul 12, 2005 10:49 PM
