Playing with the '89.
Old Jan 25, 2009 | 06:28 PM
CaptainChrysler's Avatar
Well the weather is still crummy, but we had to test out the hoodstack. Installed a version of the RCC lift as well. Sits basically level now. Still plan to get air bags to compensate for the weight box.
Here is some 3rd gear launches:
Old Jan 25, 2009 | 06:47 PM
DNRCustoms's Avatar
Did you make the drop front hangers?? They look pretty good... those front springs on the other hand are arched pretty bad... How much drop over stock are the new spring hangers??
Also looks like you got a little tranny leak!!
Old Jan 25, 2009 | 06:53 PM
Alwaysworking's Avatar
alwaysonDTR
sure spools fast and looks cool,
fix that power steering leak or is it diesel
Old Jan 25, 2009 | 07:00 PM
I made the brackets and shackles, 3/8" plate. Google "rcc lift" and you will find plans/prints for them. They have the shackle flip for the rear, too. Gives basically 3" over stock.
If you use the plans the outer rivet/bolt does not line up. It is too far to the rear. Drilling the holes larger made it fit.
The red stuff is atf in the power steering. We also rebuild the steering gear. Had to bleed it out.
Old Jan 25, 2009 | 07:24 PM
DNRCustoms's Avatar
cool, I make all my own shackles... Just wondering if you bought or made them..
Old Jan 25, 2009 | 08:58 PM
Sweet truck.
take it back by the previous owner and show him what you did to it and give him a ride.
does that have the stock clutch still?
Old Jan 25, 2009 | 10:20 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
You still runnin the stock sticks in that Curt
Old Jan 25, 2009 | 10:34 PM
W150CTDproject's Avatar
did u have to get longer brake lines and a drop pitman arm?? Cuz i need to do that to my 90 to give me clearance between my Chevy (yea i kno) axle and my oil pan cuz of my 4wd conversion. She sits a little too close for comfort for me.
Old Jan 26, 2009 | 05:53 AM
Unfortunately they are still the stock injectors.
A droppped pitman arm or dropped drag link would be ideal. The brake line has plenty of slack. You can see it in the pics.
I am thinking about x-over steering now, looks like it will fit. We tapped the box for hydro assist, just got to get the cylinder.
Old Jan 26, 2009 | 03:46 PM
Looks kinda funny with the stacks in the bed still.
Old Jan 26, 2009 | 04:12 PM
fanbrain's Avatar
Hook it up so smoke comes through all 3 stacks.
Not sure how that would work though. I imagine a creative enough individual could make it work, given plenty of flex pipe and 90's.
Old Jan 26, 2009 | 04:13 PM
Now THAT would be something to see!
Old Jan 26, 2009 | 05:43 PM
fanbrain's Avatar
In-bed dual stacks AND duals exiting behind the rear wheels; that would be easier to plumb and more people would hate your for doing it.
Old Jan 28, 2009 | 10:01 PM
i wonder.......make those so it's 6" taller. THEN get a 6" lift lol That'd be one taaaaalllllllll truck.
Old Jul 4, 2009 | 11:17 AM
torqmonster's Avatar
Nice job on the lift brackets!
