piston pump
piston pump
i have got all of the part numbers from the tech fact section on this site for the piston lift pump. I was jsut wondering if that is all of them or if there is anything else i need.
Nope just have to grind or cut off a big section of the tappet cover insulation either with a die grinder or shop knife. I removed the old pump and fuel line, then with duct tape covered up the fuel supply line and the hole in the block to keep the junk out when grinding.
