piston lp question
Old Feb 26, 2010 | 06:56 PM
Onemoparnut's Avatar
piston lp question
I called my local cummins dealer with the part numbers today and they said the lp was 200 bucks does that sound right? Is there a place online to get them?
Old Feb 26, 2010 | 06:59 PM
Rick 12v CTD's Avatar
probably around the right price.
It's $255 here.
Old Feb 26, 2010 | 07:05 PM
KD93's Avatar
If you go to 1stgen.org, in the sticky there you will find part numbers for both International Harvester and New Holland. Both of those OEM's use the same pump, and can be had for somewhat less.
Old Feb 26, 2010 | 07:23 PM
I just found it online for 124 bucks. They also have the rest of the parts for half the money my local dealer wanted
Old Feb 26, 2010 | 08:37 PM
mhuppertz's Avatar
Just make sure it's the low pressure piston lift pump.
Old Feb 26, 2010 | 08:54 PM
TrkEnvy's Avatar
Could you pm me with that site? I have been wanting to go piston pump too.
Old Feb 26, 2010 | 08:58 PM
I got the part number from the sticky and they match exactly. So then it should be the correct one right?
Old Feb 26, 2010 | 08:59 PM
mhuppertz's Avatar
Yes, should be.
Old Feb 26, 2010 | 09:54 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
i got quotes 260 just for the pump so i am going to order from a member off 4btswaps.com. the "case part" is apparently even more expensive now than the cummins.
Old Feb 26, 2010 | 10:38 PM
BearKiller's Avatar
For what it's worth,
Independent Cummins parts sellers, be they agricultural, industrial, vehicular, or any combination of the afore, set their own price schedules, making as much or little profit as they please.
Every piston lift-pump I have laid eyes on is made by CARTER; I wonder if one could circumvent Cummins and buy them under the CARTER label.
Old Feb 26, 2010 | 11:52 PM
jimbo486's Avatar
i paid $186 for mine back in august (2009). it says cummins on the label too. i was in it for almost $230 with tax for the gaskets, fuel line and seals.
Old Feb 27, 2010 | 05:29 AM
I called 3 local dealers here and they were all pretty close in price at 310 dollars for everything I need. T can get everything from the plaqce online for 185 bucks plus shipping. That is a big difference.
Old Feb 27, 2010 | 05:38 AM
Jungle's Avatar
Give Gary at Southeast Power Systems @ 386-274-2111
He has great pricing!! That's where I get my Cummins parts.
Jim
Old Feb 27, 2010 | 06:18 AM
BearKiller's Avatar
I do know that there is a pretty steep mark-up on parts; but, you also should be aware that there are several really cheap chinese knock-offs out there that ARE NOT MADE BY CARTER.
Although, the foreign pumps may be as good or better, who knows.
If this good price you have found is genuine CARTER, then I would go for it.
Are you the moparnut of two-cycle oil fame ??
Old Feb 27, 2010 | 08:21 AM
I entered cummins part number and that is what I was he info I was given I will have to give them a call and fond out for sure. I don't think I am the moparnut of two cycle oil fame. I have run a lot of waste oil but not two cycle oil
