piston lift pump or not?
Old Aug 20, 2010 | 12:25 AM
MARF75's Avatar
I have my 93 W250 torn down to the bare frame and axles,and am puuting it back together 1 piece at a time.While I`m in this process i`m doing everthing I can to put it back together RIGHT! I`ve spent quite a bit of time reading over the sticky`s.
I was wondering if it is neccesary to change over to the piston lift pump for stock duties,as of right now? I was also thinking of doing the homegrown fuel pickup upgrade/supply that is layed out in the sticky section.
Is this something I should do while Im putting this back together? (I m trying to do this on a budget to get the truck on the road A.S.A.P.)
Old Aug 20, 2010 | 01:21 AM
ofcmarc's Avatar
It sure wouldn't hurt.
Old Aug 20, 2010 | 05:19 AM
Jungle's Avatar
It's a lot easier to replace it with the body off & it would be new when you get the truck running.
Jim
Old Aug 20, 2010 | 08:56 AM
MARF75's Avatar
Jim
I gues another question i have is, What is the purpose for thepiston pump?Are the diaphram pumps weak or prone to failure?
Old Aug 20, 2010 | 10:24 AM
The_Head's Avatar
Yes they are, even in stock trucks.
Old Aug 20, 2010 | 10:46 AM
Onemoparnut's Avatar
My stock pump failed and left me hangin once.
Old Aug 20, 2010 | 01:12 PM
MoPowa's Avatar
If you ever plan on turning up the pump and putting injectors in, that little diaphragm will not keep up. It's well worth the money, and very easy to install. Otherwise for a stock fuel system, I doubt it you would really need it besides just having the assurance of a more reliable piston pump.
Old Aug 21, 2010 | 12:18 PM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
i noticed a small improvement when i did my piston lift pump. i'm running stock injectors. just seems like a bit more smoke and seat of the pants feel. also might help you VE live a bit longer if you ever run the rpms up high.
Old Aug 21, 2010 | 12:23 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
as soon as i did injectors i knew i had to have one.. id get up to 30 psi of boost and then it would drop to 25... swapped in the pump and it went to 32 i think (stock turbo) and would stay there all day.
Old Aug 21, 2010 | 01:25 PM
Montana2x2's Avatar
If the piston lift pump fails it cannot dump fuel into your crankcase like the diaphram pump can. Just for this reason I think it's a good upgrade.
Old Aug 23, 2010 | 11:23 AM
#2isgreen's Avatar
I imagine that with better fuel pressure the VE can use more energy to send fuel to the injectors instead of sucking fuel from the tank through the little diaphram pump. Perhaps this results in a better atomized spray from the injector? Finer drops burn quicker for higher hp? Not sure but it all sounds possible...
Old Aug 23, 2010 | 01:32 PM
roxxx's Avatar
I just priced new piston pump out here Just the dang Pump is going to cost me 330 Canadian and that's from a Case Dealer . Would like to hear the prices in the US ??
Case is expensive for the pumps now. Look for a cummins parts dealer.
Old Aug 23, 2010 | 01:34 PM
roxxx's Avatar
Same up here from Cummins
Old Aug 23, 2010 | 03:07 PM
Originally Posted by MARF75
I guess another question i have is, What is the purpose for the piston pump?Are the diaphragm pumps weak or prone to failure?
My new diaphragm pump lasted a whopping 3 weeks before it left me stranded. I now have a piston pump set-up.
