Piston Lift Pump Install
Old Feb 24, 2011 | 07:38 AM
  #121
jesussaves's Avatar
anyone know what the total price is currently for this swap with original cummins parts?
Old Feb 24, 2011 | 10:31 AM
  #122
Richie O's Avatar
366 Spring Chicken
Last price I had on the pump only was $185.00 right from a cummins dealer. The rest slips my mind.
Old Dec 21, 2011 | 11:28 AM
  #123
jimbo486's Avatar
Originally Posted by jimbo486
For any future piston pump buyers, here are the part numbers and prices as of August 17, 2009:
(1) Pump | P/N 4988751 | $186.61
(1) Supply Line | P/N 3914753 | $35.74
(2) Supply Line Seals | P/N 3963983 | $1.27 ea.
(2) Gaskets | P/N 3939258 | $2.10 ea.
(1) Spacer | P/N 3914284 | $12.86
Just a heads up for anyone so you don't have to search every page.
Old Dec 21, 2011 | 05:19 PM
  #124
The_Head's Avatar
Why is the low pressure pump more money than the high pressure version?
For about $40 more you could run the HPPLP and a regulator, and be done with it.
Old Jan 23, 2013 | 02:04 PM
  #125
Huck's Avatar
Oregon Fuel Injection sells a kit for $132 - HFP702-kit:
http://oregonfuelinjection.com/index...EL_SUPPLY_PUMP
HFP702 is the Delphi pump only and goes for $65.
Also, note the kit doesn't supply the 2 supply line seals (P/N 3963983)
I'm told this is the low pressure pump that puts out ~7psi at idle.
I haven't installed mine yet, but when i do i'll let you know how it went!
Old Jan 23, 2013 | 06:46 PM
  #126
SChandler's Avatar
The Cummins low pressure pump puts out 12-15psi. The Delphi piston pump is barely better, pressure-wise, than the factory lift pump which puts out 5 psi.
Old Jan 26, 2013 | 02:19 PM
  #127
1972RedNeck's Avatar
The Case IH part numbers are as follows:
Pump 87473336
Tube J914753
Spacer J914284
Gaskets (2 Required) J939258
Seals (2 Required) 87415913
Old Oct 31, 2015 | 06:19 AM
  #128
mudbuster's Avatar
I am wondering why the spacer is needed, is it just to add some clearance externally or does the cam lobe need it internally? Without it will the cam ram the piston too far?
Old Oct 31, 2015 | 06:43 PM
  #129
peckens's Avatar
Correct
Old May 7, 2016 | 01:46 PM
  #130
Budman56's Avatar
Question Lift pump #3936318
Is this the correct pump to be using on my 1st gen 5.9 this thread is old and a lot has changed and there are several different part numbers and China made crap.
Old May 7, 2016 | 01:50 PM
  #131
Budman56's Avatar
Question China Lift pump
These are $30 are they any good?
Old May 8, 2016 | 11:50 AM
  #132
nascar mark's Avatar
Best to use a known quality product, not a cheap knock off. There is at least 2 companies selling the Genuine Cummins correct high volume, low pressure lift pump with the safe max pressure of 15/16psi for the VE rotary inj pumps.
Old May 8, 2016 | 12:35 PM
  #133
BC847's Avatar
1st Generation Admin
Who? THD, and . . . .. ?
Old Jul 27, 2016 | 06:49 PM
  #134
ofelas's Avatar
Dieseltuff.com for a better price and support second to none.
Old Jul 29, 2016 | 12:10 PM
  #135
cougar's Avatar
I'm just trying to figure a way to get my fat but in there to do it.
