picture; dana 70 limited slip.
Old May 12, 2004 | 09:15 PM
92extle's Avatar
Can someone please post a pic of a dana 70 limited slip rear end for me. Mine sounds like it's coming apart when i turn corners on dry pavement. Used to be just when I turned right, now it knocks both ways. I just want to sure it is a factory unit and not an aftermarket locker. When I swapped the fluid it didn't look like any L/S I'm used to seeing. And yes I added friction modifier times two. Thanks guys. BTW 265000 kms.
Old May 13, 2004 | 12:55 AM
bigred496's Avatar
ooh, not fun, i had a problem similar to this in november. it started out with a jolt every now and then on turns, then it got to where i had to hold the clutch in on a turn until the wheels spun at the same speed again, and finally when i was limping it home from school, it just slipped while driving in a straight line. i had to get it towed the rear-end shop, and 1100 dollars later i had a new rearend. thanks to my mom and dad of course.
Old May 13, 2004 | 06:32 AM
jughead's Avatar
i hear a lot on different boards about differential chatter. most say it will tear it up. i worked for a chry. dealer for ten years. 64-74. the clutch type posis had this problem. an additive fixed some but not all. i only remember replacing clutches in 2 units. at that time chry would not do anything for the chatter. said it would not hurt the unit. i have always used the clutch type unit, still do. in all these years i have never had to replace the clutches in the first one of my own. i use gl-5 or better gear lube and dont worry about it
Old May 13, 2004 | 12:55 PM
j-fox's Avatar
As far as color goes, the dark fluid is from the clutches.
The chatter or shaking is from the clutches. They need more additive. Try 4 oz. Buy it from Dodge.
94 dodge
17
Feb 14, 2006 09:27 PM
shawn085
Nov 21, 2005 12:46 PM
dkinzer
May 23, 2005 08:57 PM
jdjoe_97
28
Mar 24, 2005 09:19 PM
HATCHMAN
Nov 7, 2003 01:02 AM
