Pcm only works when warm?!?!?
Old Sep 28, 2013 | 09:27 PM
Shipskym's Avatar
My pcm works normal when it warm but after it gets cold when you turn the key there is no wts light until you turn the motor on and there is no alt chargeing until the pcm warms up sometimes if i unplug the air temp sensor it makes the grids work before i start the truck, and if the grids work before i start the truck then i have no problems at all, so why does it work when warm but not cold.
Old Sep 28, 2013 | 10:36 PM
j_martin's Avatar
Could be a connector moving with the temp and opening. More likely it's a fault in the PCM itself, like a cold solder joint, or a failing component.
Old Sep 29, 2013 | 12:19 AM
simplysmn's Avatar
Yeah sound's like a bad PCM
PM me if you need 1
mtb1982
55
Jan 20, 2020 10:45 AM
klx650a2
Jul 22, 2008 06:47 PM
herb
Jul 18, 2008 08:25 AM
Big Perm
Dec 18, 2007 08:44 PM
