Passenger side front fender molding?
You bought the complete moulding, not just the black plastic piece?
If it's the moulding I believe it wraps around into the wheel wheel and is attached under one of the bolts or screws. Then there is two or three clips you have to pop loose. You need to carefully press downwards, at the same tip pull the bottom out towards you....that should pop the moulding off the clips.
oilcan64
Mar 7, 2009 09:25 AM
akapun
Dec 17, 2004 12:59 PM
