Passenger Door Problem
Old Mar 28, 2013 | 05:44 PM
rrgrassi's Avatar
So, I changed out the door hinge pins and bushings. I used Faith's write up. but used a ratcheting tie down to hold the door, since my carport has 2x8 rafters.
The door open and close soooo much better!
Anyway, the passenger door front edge still rubs the rear edge of the fender. How can I make the fender move a bit toward the front?
Thanks!
Old Mar 29, 2013 | 06:47 AM
Smokin$$away's Avatar
I've never done a Dodge but have done several furds n chebbies. Should be bolts underneath, maybe inside, and on top of the fender at the rear. Loosen off and move your fender forward. Good luck!
Old Mar 29, 2013 | 08:43 AM
thrub's Avatar
Check the cab mounts also. A mount gone on the front or rear corner might be why your fender is hitting.
Old Mar 29, 2013 | 09:52 AM
rrgrassi's Avatar
Cool! Thanks guys!
Old Mar 29, 2013 | 10:34 AM
rebal's Avatar
if you cant slide the door hinge back (hinge bolts slide on cab and door) I have put flat washers under the hinge on each bolt of the door that will shim it back too .
Old Mar 29, 2013 | 12:10 PM
j_martin's Avatar
Beat the front edge of the door inward with a ball peen hammer so it clears.
Old Mar 29, 2013 | 01:01 PM
thrub's Avatar
I used the above method on my 93. Effective, but not pretty.
Old Mar 29, 2013 | 01:24 PM
rrgrassi's Avatar
I was thinking about beating the fender edge, as it is easier to hit when the door is open!!!
Old Mar 29, 2013 | 05:21 PM
j_martin's Avatar
Wasn't really serious, but I guess I'm not the only one that has gotten a bit more service out of a bent car or pickup (usually caused by pushing on the deer herd) by beating the front edge of a door into submission.
rockjeep
Mar 12, 2008 11:55 AM
getmygun
Dec 7, 2006 10:08 PM
Luckycharm1
Mar 3, 2006 10:19 PM
rico334
May 5, 2005 10:13 AM
CCOUGHRAN
15
Feb 27, 2004 01:38 PM
