Parking lights on my 93 going crazy
Old Mar 29, 2013 | 10:32 PM
doug holt's Avatar
Hello guys
Well I was going to leave last night pulled head light switch on. Then noticed no parking lights. Today I start in on it after checking all fuses are good, I pulled switch out to test the wires to be hot at plug. There was one hot one i believe. Then I stop to go in the house get cup of ice turn around and look the park lights in the grille and the tail lights were working front fender lights were not working
The head light switch was not on. They would stay on with the switch unplugged. I pulled inst. cluster out. Would that make a difference? What color are the wires that should be hot for parking lights at plug? Any help would be awesome and thank y'all for being so helpful in the past thanks Doug
Old Mar 29, 2013 | 11:37 PM
torquefan's Avatar
If you have a trailer connector on the back of the truck, the first thing I'd do is have a look inside both ends of it and see if it's full of slush or mud that's partially shorting two circuits together.
Old Mar 30, 2013 | 01:26 AM
haultruck's Avatar
Every park/running light on my truck is 18 gauge blk/yl all the way from the switch to the farthest light. The 91.5 wiring diagram in the sticky is the same. Good luck
Old Mar 30, 2013 | 02:34 AM
93-12Smoke's Avatar
Does the plug look like its starting to melt?
Old Mar 30, 2013 | 11:51 AM
cougar's Avatar
"Then I stop to go in the house get cup of ice turn around and look the park lights in the grille and the tail lights were working front fender lights were not working
The head light switch was not on."
There is your clue, "The head light switch was not on."
The only other place the parking/running lights can get power is through the warning flasher circuit. So either the flasher unit is bad or the multifunction (aka blinker) switch is bad.
Old Mar 30, 2013 | 11:17 PM
doug holt's Avatar
No sir replaced the. Plug I thought it had a wire loose but I couldn't find a wire that was a bad connection it does seem like the flasher switch is not working properly will check in the morning and get back with you guys thanks to all of y'all
Old Mar 31, 2013 | 07:25 AM
Smokin$$away's Avatar
Wiring problems are pita! I hate electrical problems, but I like the challenge. No no I tolerate the challenge if and when I have time and get my feeble mind into it! My ole ride has wiring gremlins and I'll have to address the problem. I have bought and built the headlight relay setup Jim Lane came up with, just haven't installed it yet. The wiring/engineering on the electrical on these ole rides are at the FAR end of being undesirable. Good luck with it!
Old Mar 31, 2013 | 12:55 PM
doug holt's Avatar
Ok last night I just couldn't stand it I was out watching fire burn by chicken pen I went in shop and dug out a two way cig lighter plug in and tied it into a wire that was already hooked up to my black and yellow(or white) the one for parking lights. I.C.E. when I did everything is working perfect. Would that mean it is the head light switch? Blinkers and hazards both work properly. Thanks again. Also, since I pull a trailer half the time I was thinking about going a head and put them on a toggle switch. For sure trailer lights wouldn't hurt. Y'all are all such great help this forum is awesome
Old Mar 31, 2013 | 03:46 PM
Boatnik's Avatar
Head light switch is a good choice. They see a lot of amps. I replaced mine several years ago and relayed the head lights when I upgraded the wiring. So far I haven't had an y more trouble.
Old Mar 31, 2013 | 03:50 PM
j_martin's Avatar
When power gets into a circuit from some other (unknown) source, it usually means that a switch, connector, or even a wiring harness is failing in a big way. Don't find it, and you're setting yourself up for a fire.
Banzai Bob
Feb 24, 2010 12:24 AM
rdmartin108
Aug 19, 2007 08:06 PM
craneage2001
Nov 9, 2006 07:07 AM
CHarlan
Aug 6, 2003 08:40 PM
