Pacbrake for 01,will it work for 90?
Old Jul 25, 2008 | 09:38 PM
u.s mma's Avatar
I expect that the outlet size on my 18.5 is different, that is going to change this year anyhow. I have a line on this brake cheap, no install directions. i can fab a bit, so making it fit could happen, but are there any electrical differences? I know i need 60psi valve springs. any info or opinions are appreciated, i would like to get back to the guy as soon as possible.
Old Jul 25, 2008 | 10:23 PM
ofcmarc's Avatar
I think (???? OW! that hurt! ???) it will fit with the correct turbo and 2nd gen DP... maybe...
IIRC there was a thread awhile back with a 1st gen using a 2nd gen exhaust break and DP.
Old Jul 25, 2008 | 11:03 PM
C/PRD/'s Avatar
It can't be that difficult. Big deal on the fabbing, the controls may be the most difficult.
Old Jul 26, 2008 | 07:24 PM
The control side won't be hard. Run the vacuum solenoid off a microswitch triggered by the throttle linkage.
Old Jul 27, 2008 | 09:53 AM
u.s mma's Avatar
Well, Im going to try and see the guy tonight, what should I look for as far as complete wiring? I figure if it is missing anything a new harness could be had from pacbrake. What about the condition of the brake itself? Not to much to go wrong aside from a sticking butterfly valve is there?
Old Jul 27, 2008 | 03:54 PM
As long as the butterfly moves when you apply vacuum to the actuator, the brake itself is OK.
RobG
Apr 12, 2012 06:15 AM
96_12V
Jul 7, 2005 11:26 PM
IH8MYCAT
15
Apr 16, 2005 10:36 PM
dwinnett
Dec 28, 2004 12:03 PM
