Overfilled & Smoooth
Drained & overfilled the gearbox yesterday, and am I glad I did. First, it's a rebuild, and the oil that came out looked like silver nail polish, from break-in I guess (hope). Second, because I used synth (Walmart house brand), the transmission shifts much more smoothly & easily. I didn't have as much trouble as I thought i would re-seating the shifter, but a rag or glove is essential for pushing down & holding it comfortably. Also, MAKE SURE that the transmission is in neutral before removing the shifter, or replacing it will be a pain in the rump. I had to find neutral with a screwdriver in order to finish. Oh-- and I gave it an additional quart.
- Chris
- Chris
Ya it be allmost a week with mine and vary happy with the resoults!!!!!
You said that it came out silver? scary! did the fill plug magnet have a lot on it?
How long is you warnty on the tranny rebuild?
I had the same issues.. when I bought my '92 it would get stuck in 5th gear.. I drain fluid.. and overfilled tranny with Mobil 1 Syn and have not had one problem with shifting since.. it is very smooth and has not got stuck in 5th gear once since
You said that it cam out silver? scary! did the fill plug magnet have a lot on it?
- Chris
I would be willing to bet your silver oil is from aluminum worn off of the shifter forks. The most likely cause is excessive endplay of the mainshaft. I would check it again pretty soon as you will likely have trouble in the future. My 1990 had some silvery oil come out of it and the main shaft had over an 1/8 inch of movement. My .02.
mr. ed
01-02-2008 05:23 PM
1stTimeAround
13
04-25-2007 06:45 AM
