Overdrive? TPS? Speed Sensor?
Old Mar 29, 2004 | 12:44 PM
ouchman's Avatar
I asked a similar question recently but I may have misunderstood the answers I got. I'm going to rephrase the question...
My truck is having trouble shifting into (and dropping out of) Overdrive. I did a search and read some posts but I am a diesel-novice and need a little guidance. My truck is a '92, auto trans. The speedometer is reading correctly (no bouncing) and, except for overdrive, the tranny is shifting normally.
Do I need a new Speed sensor? A new TPS? What do you suggest?
Old Mar 29, 2004 | 01:32 PM
apache's Avatar
I just finished fine tuning my o/d shifting. do a search on TPS adjustment and all the info you will need is there, its easy. there is a few different reasons for the shift oddities, fliud temp, and TPS settings.
Old Mar 31, 2004 | 02:19 PM
bumpytruck's Avatar
Mine did the exact same thing as yours and it was the TPS.
Old Mar 31, 2004 | 06:06 PM
freddy2pipes's Avatar
Before I threw the auto to the junk yard, I would unplug my tps and clean the connections with some electronic cleaner. Sometimes just unplugging and plugging it back in would cure it for a while. Never replaced it because of the cost and the plans to install a 5-speed.
whosdunit
May 17, 2014 08:54 AM
MR HYDROSEED
Jan 19, 2008 11:27 AM
supr
18
May 21, 2007 09:29 AM
warden
Feb 8, 2004 05:57 PM
Dino
Mar 4, 2003 08:01 PM
