overdrive temp sensor
Old Jul 16, 2007 | 03:09 PM
One Tree's Avatar
anyone know where this little guy might be located??? overdrive temp sensor
Old Jul 16, 2007 | 03:29 PM
leper's Avatar
It is in the outpul line of the transmission. Th line that goes toward the front of the truck on the drivers side, at the bend.
Old Jul 16, 2007 | 03:42 PM
One Tree's Avatar
it has threads on one side and the plug on the other... i have no idea where to look. i have the new one in my hand... just have to find the old one to swap it with....
Old Jul 16, 2007 | 03:45 PM
leper's Avatar
Get under the truck. Get on the drivers side. Look at the 1/2' line coming out of the transmission, in the front (not the back)going forward. Where it bends is where the sensor goes. It is about right below the linkage brackets at the front edge of the trans pan. About 2 inches from the transmission. If you find the edge of the trans pan at the drivers front corner, you will see it.
Old Jul 16, 2007 | 04:02 PM
One Tree's Avatar
yesser
after my last post i went out and sure enpugh... you nailed it. thanx!!!I took the old one out only to realize the new ones thread side was larger... old one probly 5/8 new one 3/4 ya think i could put a male/female adapter on there?? thank you again
Old Jul 16, 2007 | 04:54 PM
leper's Avatar
I'd take it back and get the correct one.
Old Jul 16, 2007 | 05:55 PM
One Tree's Avatar
thing is.. i got it from the dealer... they say that IS the correct one... its and endless battle ahahhaaa
Old Jul 16, 2007 | 09:51 PM
leper's Avatar
What part number is it?
Old Jul 17, 2007 | 07:15 PM
One Tree's Avatar
numbers
the number on my invoice is 4638763
the stamped number on the sensor is 3919909 1441
again the two parts are identical exept for the size of the male end. The ne sensor measures 3/4 across the trhreads and the old one i'm sure is 5/8. the cavity inside the sensor is a bit longer on the old one as well. if you need me to i can take pics i'm just not too sure how to put them on here. but i could email them if need be. thanx
Old Jul 17, 2007 | 08:21 PM
Jims92CTD's Avatar
Trans Temperature Switch.
The last time I bought the switch it had a part number of 56026720. This may have been superseeded with a different number but it is the right size.
Jim
Old Jul 17, 2007 | 08:26 PM
One Tree's Avatar
nice... i'll definatley check into that... lemme ask ya.. what was yer truck doin that you needed the part?? mine keeps goin in and out of overdrive, just will not stay in high gear, for the most part anyway. Ive tried just about everything.. any ideas?
12valvetom
Sep 14, 2009 07:01 PM
wise_cummins
Dec 24, 2008 08:11 AM
lonesomecur
Oct 20, 2008 11:18 PM
72demon440
Apr 27, 2007 10:45 PM
howdy62
Aug 11, 2003 05:24 PM
