Ounces of Freon
Old Jul 31, 2007 | 06:52 PM
90firstgen's Avatar
Ounces of Freon
How many pounds/ounces of freon approximately do our systems hold? Oil included. 3 pounds? Thats what I've got in there now and it acts like it would take more. I'm using a cheap filler guage so I have no idea what the high side is doing. Dumb I know... Anyway if I can find out what our systems are supposed to take then I'll be done with this. Thanks
Old Jul 31, 2007 | 06:55 PM
rbrettctd's Avatar
It should say on the core support in front of the radiator. BTW Did you pull vacuum on the system?
Old Jul 31, 2007 | 07:01 PM
90firstgen's Avatar
All of the tags on my core support and hood are faded and can no longer be read. I didn't pull vacuum on the system this time. Last time I filled it I did go to vacuum. The system still had freon in it so I just pulled the schrader valve, Screwed on my new R-12 to R134 fitting, and let it go down to about 1 psi of pressure and capped it off. Then added the 3 lbs of good freon. There should still be no oxygen in the system.
Old Jul 31, 2007 | 07:35 PM
ronnie's Avatar
The manuel I have says 44 ounces of refridgerant
Old Jul 31, 2007 | 09:20 PM
sdstriper's Avatar
Thats the same as mine, and 7 ounces of oil.
Old Jul 31, 2007 | 09:46 PM
90firstgen's Avatar
Thank you gentlemen. Helps a lot
Old Aug 1, 2007 | 07:58 PM
dpuckett's Avatar
How much pressure are you seeing on the suction side? It should be in the 22-30psi range at 90deg ambient temp. Book calls for 22-39, but we all know better performance can be had by hanging on the low side. BTW- it took one can of R134A to reach 25psi in my system; 200psi on the compressor side. This is at idle, and not 1100rpm as per the FSM, so my actual test results may vary.
DP
Old Aug 1, 2007 | 08:23 PM
jughead's Avatar
tape a good thermometer on the suction line and add gas til it gets as cold as it will add until the temp starts climbing then remove back to the coldest point. then you will have it the best it will do.
Old Aug 1, 2007 | 11:24 PM
leper's Avatar
My hood sticker says 1.08kg. I put 1.2 in and I will see how it does. It will leak down to 1.08 in a month or so.
genesis
Apr 13, 2008 05:46 PM
sluggo42
Nov 28, 2007 07:56 PM
CowboyDave
35
Aug 15, 2007 05:24 PM
linetrash75
13
Aug 24, 2006 06:14 PM
robert chilton
17
Sep 11, 2005 04:02 PM
