Opinions for horse power
Old Feb 15, 2013 | 09:45 PM
Duck assassin's Avatar
I no it right now Ill fry the tires through 1st n 2nd I wanted the converter outta a 518 cuz the overdrive
Old Feb 15, 2013 | 09:49 PM
1972RedNeck's Avatar
The overdrive is in the transmission itself, not the converter. A 47RH converter in the other hand, would be a good upgrade if you could make it work.
Old Feb 15, 2013 | 10:01 PM
93flatbed's Avatar
You can spin the rear tires all the way threw 2nd with a stock 727 on 32"ish tires with 3.07 gears? Power lock or one tire fire? What all you got done to your pump, what injectors and turbocharger?
I may need to get a Dana 71&61. I wouldn't mind the gear ratio if I could power threw it like that.
Old Feb 15, 2013 | 10:16 PM
They both spin, I have banks ic kit with stock injectors 32 gov spring Denny fuel pin turned up pump and a built tranny
Old Feb 15, 2013 | 10:17 PM
And stock turbo with the banks waste gate
Old Feb 15, 2013 | 10:23 PM
Tc's 91's Avatar
You can go pretty quick w 3.07's and a 727. 2.65x75x16's. mine went 8.0 and 12.6. Probably quicker now. Lockup tranny and gear changes are pretty expensive. 727s slip a little but don't tend to break if they have the right parts.
Old Feb 15, 2013 | 10:30 PM
The guy I got the truck from said its a built tranny with bd parts tq cover clutches valve body he said the only thing he didnt put was billet shafts
Old Feb 16, 2013 | 12:33 AM
What you got done to your truck? If you don't mind my asking?
Old Feb 16, 2013 | 06:33 AM
93flatbed's Avatar
Why don't you worry about traction before horse power? If you already have enought to burn rubber then shouldn't getting that power to the ground be the next big step?
Old Feb 16, 2013 | 10:16 AM
That's true flatbed my tires are pretty low on tread ima need a new set soon
Old Feb 16, 2013 | 10:18 AM
I need to replace my front u joint for the 4wd
Old Feb 17, 2013 | 12:44 AM
Tc's 91's Avatar
Built.
Engine hasn't been out. New o ringed head. Water to air. Methanol. Nitrous. Made 578 with ddp IV's and ddp pin. Have a Denny t pin and some coal train 6x16's but don't have numbers on them yet. Should be able to pour a lot more nitrous now. Drive ability is much better with the ddp stuff. I'll save the big stuff for the track and dyno. Timing is 20. No wipers now though. Oh well.
Old May 29, 2013 | 03:51 AM
93-12Smoke's Avatar
Are you talking about a straight up floor it from a stop burnout or power braking it?
Old May 29, 2013 | 08:15 AM
Well when I had my old bald tires I would launch it around 10psi or just mat the peddle at a dead stop and they would break loose
Old May 30, 2013 | 04:15 AM
grandaddy goat's Avatar
My 92 W350 club cab dually was completely unmolested when I got it 6 months ago with 145k miles, just a old farm truck. Took it home and turned the pump up until I ran out of idle screw, screwed the star wheel down, rotated the fuel pin, and adjusted the smoke screw for minimal smoke. I had to turn the pump back down a little because I kept smoking the tires. They still break loose if I stand in it, but not for long
Big Joe
Sep 16, 2005 03:36 PM
cummins dsl
Feb 16, 2005 12:34 PM
geer
Jul 11, 2004 09:36 AM
javamann
May 4, 2004 10:23 AM
boehunter49
Nov 24, 2002 09:40 PM
