The old clutch setup...issues.
Old Nov 8, 2013 | 08:21 AM
Subliminal's Avatar
Hey guys,
So, a few years back I swapped a Getrag into my truck. At the same time I put in a SB clutch with all the fixins.
Of course, my old worn-out hydraulics wouldn't get the job done, so I had to replace both cylinders.
Well, Here I am, a year or two later, and it's tough getting the old girl into her intial gear (2nd) sometimes, and sometimes it takes multiple tries.
So, I want to fix that, because it's annoying. But I don't know where to start. There doesn't appear to be a whole lot of adjustment available on the hydraulic systems.
Was hoping I could have some help troubleshooting?
Thanks!
damon
Old Nov 8, 2013 | 02:41 PM
Nughuffer's Avatar
Have you checked slave and master for leaks? Probably time for another slave cylinder.
Old Nov 8, 2013 | 03:24 PM
I need a new slave cylinder too...mines leaking. Someone suggested getting one with a bleeder on it. Anyone know what brand has those?
Old Nov 8, 2013 | 06:16 PM
Subliminal's Avatar
Slave Cylinder probably has under 5k on it...or rightabouts. It was a rockauto jobber. Can't believe it'd crap the bed already.
Old Nov 8, 2013 | 08:01 PM
dodgenstein's Avatar
How are the eye on the clutch master cylinder rod and the pin on the clutch pedal. I have seen some on the verge of wearing through the eye, or cutting the pin in two.
Old Nov 8, 2013 | 08:17 PM
sooty's Avatar
in and out method, measure input travel/measure output for same
Old Nov 9, 2013 | 10:39 AM
haultruck's Avatar
Does it have to be your clutch? Couldn't it be the 1st/2nd fork in your tranny? Mine has had trouble going into reverse for years, and I simply slide it into 5th and then back down into reverse, maybe I'm wrong, but I don't think my clutch has anything to do with it.
Old Nov 10, 2013 | 09:29 AM
Subliminal's Avatar
Hey guys, thanks for the replies. The pedal has some wear on the pin, but not even 1/4 way thru. There are no leaks. The clutch and pressure plate are relatively new and should be overly sufficient for my power levels, so that shouldn't be the problem.
I was thinking maybe it was the rod length, but I don't have any rod to compare it to, unfortunately...just remember hearing that the replacements are often shorter than the oe.
Old Nov 10, 2013 | 10:09 AM
mknittle's Avatar
Is there a plastic(nylon?) cap on the slave pushrod! the one from my donor was cracked and close to MIA. if it is missing that would shorten the push rod by maybe 3/16" to 1/4"!
Old Nov 10, 2013 | 12:22 PM
patdaly's Avatar
Just went thru this with a buddies Powerstroke, the clip was still there, but broken, you really couldn't tell anything was amiss till you held your hand on it while pushing the pedal, it collapsed/shifted sideways just enough that the clutch wouldn't allow engagement without grinding.
79 cents and a new clip later, all was well.
Dodgezilla
Nov 6, 2011 04:13 AM
chariotdriver
Oct 18, 2008 10:50 PM
ryanihf250
Jan 17, 2008 02:58 PM
pet05
Jun 14, 2006 10:00 PM
kandgo
Dec 28, 2003 01:34 PM
