Ok I want black smoke BAD
Old Jun 23, 2005 | 07:01 PM
sho_shane's Avatar
I just want to know what I can do under the hood of my baby to get the black smoke to poor when I get on it.. I think I heard someone say somthing about grinding some thing but im not sure and I can turn my truck up to much cus I think my trannys week ( Its just old) so tell me guys how do I get the smoke to flow
Old Jun 23, 2005 | 07:17 PM
fearthedeere's Avatar
turn ur full power screw a couple of time rotate ur fuel pin and crank down on ur smoke screw. Clear as muck right.... Look in the tech facts for the full power screw. and on the fuel pin and smoke screw.On the top of your pump there is 4 screws take those out and pull the top off under there there is a rubber thingy pull that out and thats ur fuel pin look at it and you can tell its off set to one side.put the side that is "deep" toward the radiator. put the top back on and there is as round cap on it get the cap off and there should be a torx screw and 13mm (im thinkin thats the size) nut break the nut lose and crank down on the screw til desired smoke i think is how its worded. And Diesel Gurus if im worng somewhere correct me please.
Old Jun 23, 2005 | 07:55 PM
dezlsmkr's Avatar
http://dodgeram.org/tech/dsl/more_power/Power_ve.htm
That'll save some typing
Old Jun 23, 2005 | 07:58 PM
cheater
Old Jun 23, 2005 | 08:00 PM
dezlsmkr's Avatar
nooooo LAZY
Old Jun 23, 2005 | 08:12 PM
G1625S's Avatar
smoke=heat, so you better have yourself a pyro---these non i/c trucks get hot FAST
g
Old Jun 23, 2005 | 08:17 PM
sho_shane's Avatar
I see what I can do now can I do all of it with out hurting my truck and what guages do i need to have befor a do it???
Old Jun 23, 2005 | 08:25 PM
G1625S's Avatar
A pyrometer is an absolute must if you have any sort of attachment to your rig. Everything else you can do without....for now...tach-you can't rev past the governor anyway. boost-while a good indicator of what's going on with fuel/air delivery, a boost gauge will not tell you when you're pushing more heat than the engine can stand...the pyro will.
g
Old Jun 23, 2005 | 11:57 PM
rebal's Avatar
you want smoke? just take the spring out from under the diaphram, she will smoke like an old coal stack any time you mash it
Old Jun 24, 2005 | 03:39 AM
bgilbert's Avatar
ditto on the afc spring. Also get the boost and pyro gauges first before any other mods.
dizelnut
Sep 25, 2007 02:40 PM
RJOS
16
Sep 3, 2007 09:19 PM
dirtydemon
Aug 6, 2007 06:49 PM
rebel05
16
Jan 18, 2007 03:34 AM
ox
21
Oct 14, 2002 12:01 AM
