OD Question
OD Question
I know this subject has been discussed to death on this forum, but I'm still having problems. I checked the TPS sensor and it works per the proceedures in the sticky. I adjusted the TV cable as well. Still no overdrive. I feel the transmission shift twice from a full stop. I have 3.54 gears and at 60 MPH I'm at 2500RPM.
Check the crank sensor cable. Mine was been rubbed through by one of the pulleys causing a minor short. It eventually rubbed all the was through which caused the Alternator to stop charging, that's how I noticed it. Once it was all spliced back together truck starting charging and shifting into OD
mkeanglorldo56
Nov 4, 2007 12:34 PM
Murf
Aug 17, 2007 04:36 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
