o/d switch
Old Oct 3, 2004 | 10:54 PM
Dan Brooks's Avatar
Not sure exactly what you're trying to accomplish, but you can add another switch and keep the factory one operational. Connect one terminal of the new switch to a ground, and splice the other to the orange/white wire from the factory OD switch.
If you're just wanting to put a switch in a more convenient place - can't figure out why Dodge put the switch at the bottom of the dash - I'd suggest swapping in the shift lever from a newer Dodge truck, which has the OD switch built in. That is one of the best mods I made.
Old Oct 4, 2004 | 10:13 AM
apache's Avatar
A while back there was a post on putting a switch on the end of your shifter. it requires the type of switch that wprks like a horn switch. one touch will do the job. you dont want a permanent type flip on/off. Make sence?
Old Oct 5, 2004 | 10:49 PM
93w250's Avatar
I got it from Radio Shack and used a rubber "foot" that I got from the hardware store. I tapped into the orignal wiring so both switches work the o.d. All you need to do is momentarily ground the od to toggle it on and off.
92smokin blacky
Sep 1, 2010 09:55 PM
smokeyram
Aug 21, 2009 06:19 PM
Barryn
Jul 14, 2008 09:30 AM
SPLnut
Dec 31, 2007 11:27 AM
redramnc
Mar 28, 2005 06:58 AM
