now she runs!!!
Old Oct 3, 2005 | 04:19 PM
skchevota's Avatar
now she runs!!!
I finaly got here running over the weekend, I pulled the electric pump I had in the tank out and she fired right up, once I droped the Idle down a bit I took here for a ride. I like!!!!!! Then my rear main started to gush, so sunday I got to pull the trans to replace that. I noticed a small pited area near the outer seal lip. I belive this is just the dust seal and the inner lip is the oil seal, to be on the safe side I knocked the new one in just a little more, not much maby a 1/16. I drove 50 mi to work this morning and so far no leaks ,,,from that. I hope that solves the problem. Now I have to figuer a beter way to vent my T case, it vented fluid all over my trany this morning. Any Ideas??? its an NP 241, that uses auto trans fluid . I used a fuel filter and then ran the line up to the top of my bell houseing area, It used to work fine but my t case sits at a little diferant angle now. Also , do you guys have any problums with clutch chatter, or drive train shutter, I can take off in 1st but if I do 2nd it starts to shutter???? any Ideas please, I was thinking maby traction bars?
I also added a picture finaly
thanks
Old Oct 3, 2005 | 04:50 PM
Tuckerdee's Avatar
Drive train stutter, when starting out, is usually caused by worn motor mounts or transmission mounts.
Old Oct 3, 2005 | 05:27 PM
andyr354's Avatar
awesome pic, nice rig. Now I just need under hood pics and specifics in case I get a wild hair to do it to mine some day
In the pic it looks like a passengers side output tcase, guess I thought all NV241s were drivers output.
You might search around on some 4x4 boards for answers on the transfer case issue. I think the NV241 has a pump in it.
Old Oct 3, 2005 | 05:37 PM
G1625S's Avatar
I'll second the motor/tranny mounts, but your flywheel could also have some oil on it from the rear main blowout yet...Sweet rig, nice to see something different.
greg
Old Oct 3, 2005 | 11:42 PM
timb's Avatar
I'm leaning towards the flywheel having some oil on it from the rear main seal.that will cause a shutter in a heart beat.
Old Oct 4, 2005 | 09:51 AM
skchevota's Avatar
Sorry, I wasnt able to check online last nite. I replaced the moter mounts when I installed the moter, the tranny mount was a new one I had ,for a diferent application, it might be to soft? yes it is a pasenger side out put on the Tcase, I used a chevy version from an 89 k5 blazer. they made this version for a few years,I had to install the dodge 29 spline input though, and found the intermediat bearing was also different.
gscoker
16
Feb 17, 2013 01:52 PM
Beast2B
Dec 8, 2009 01:44 PM
wilderness
Sep 17, 2006 08:23 PM
jeffteel
Nov 1, 2003 09:09 PM
thumper
May 13, 2003 03:18 PM
