non i/c pistons and marine injectors
Old Nov 3, 2009 | 07:34 PM
big stinky's Avatar
So from all of the research i have gathered, non i/c pistons have a larger bowl, and a point more compression than the i/c version. If anybody has a picture, please post. There is a picture floating around with intercooled vs marine, but not i/c vs non i/c.
Does anybody know the spray angle/pattern of the stock 4 hole non i/c injectors?
From most things i have read so far, marine injectors, or pods for that matter would work well with the non i/c pistons.
Anybody have any input on this?
Thanks...
Old Nov 3, 2009 | 07:38 PM
jimbo486's Avatar
i have pictures of my pistons with the head off, but nothing to show comparison between i/c and non i/c. i can still post if you'd like.
Old Nov 3, 2009 | 07:52 PM
big stinky's Avatar
sure, maybe somebody has pics of an intercooled piston they could post, then it could all be in one thread...
Old Nov 3, 2009 | 08:05 PM
big stinky's Avatar
Here is a pic of marine vs an i/c of some sort. Not sure if its late 1st gen or early 2nd gen.
Old Nov 3, 2009 | 08:41 PM
oilcan64's Avatar
correct me if im wrong but would the marine engine have more compression?
Old Nov 3, 2009 | 08:51 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
Here is a N/IC piston in my 90
Old Nov 3, 2009 | 09:10 PM
Benjamin b2's Avatar
i love my pods in my non ic 91, i didnt see much more heat than my stockers
Old Nov 4, 2009 | 12:15 AM
big stinky's Avatar
Anybody have an application list of marine injectors? Im thinking about trying a set on my pig...
What would have to be done to 370s to make them work? Bore adapters, and pop pressure reset?
Old Nov 4, 2009 | 12:50 PM
crewcabxlt's Avatar
ive ran pods in both i/c and non i/c motors. they run a litttle cleaner in non i/c becuase of different bowl.they make a little more power vs stock 4x12 non i/c injector. however ther stock non i/c injector is a great all around injector, i would still run them if i hadnt switched heads on my crewcab ford. i still run them in the farm truck.
Old Nov 4, 2009 | 12:56 PM
Old-stuff's Avatar
compression
Oilcan
Smaller bowl might not mean higher compression. That can be controled by "compression height". That is the distance from the wristpin center to the top of the piston.
Ray
Old Nov 7, 2009 | 03:34 AM
NO_SPRK's Avatar
i dont see paying that money for PODs when you have non-ic injectors. go big or go home
DodgeRam24V
13
Oct 27, 2011 11:28 PM
RollinCoalSmoke
May 29, 2009 09:20 PM
skynyrd
Jan 10, 2008 06:41 AM
ddestruel
May 10, 2005 12:17 AM
RedRotors
Dec 17, 2004 10:38 AM
