No smoke, minimal boost-
Originally Posted by devildog5001
I thought I would let you guys know how things turned out with the final adjustment to the index marks on the throttle linkage. I moved it one tooth and problem solved!! I'm up to 20 lbs of boost and my truck runs stronger than it ever has. Thanks again for your advise, I would have been hosed without you guys! Just for my own knowledge, and maybe someone else that might run into this one day, what happens if your one tooth off in the opposite direction? Looks like you might not have enough room in the idle stop to turn down the idle low enough. Anyway the truck is running great, really cool to see so much potential after driving the same truck for 9 years and 150,000 miles bone stock!
Confirm no boost leaks, then check the guide pin for movement. It is located inside the AFC housing and it's what rides up and down on the AFC cone or fuel cone....they can get sticky and that will prevent or reduce the amount of boost fueling.
pb....
pb....
SaltyDog,
Keep in mind mine was 'one tooth off' because I had tampered with my pump. If your pump is stock it would be in the correct position and your problem lies somewhere else. I'm making much better boost now because of the few upgrades to get more fuel too.
If your down on power without any changes you might want to start with your lift pump (fuel pump) since your filters checked out OK. After you locate the problem, there are some great ways to build more power without spending much money. Check out the Tech section of this site for some ideas and a lot of info on the pump itself. You can also search the 1st gen trucks with words like 'more power' and you'll get days of good reading material from previous posts. If you need more help just start a thread with a question, you'll received tons of help from some great guys. Good luck, good to see another Dog around here!
low c1500
33
Sep 21, 2005 08:29 AM
