No charge, OD, A/C, WTS Etc.
Hello, Very infomative site. Hope you folks can help. I have a 93 D-350 auto. Had a no start situation, Got that part fixed(2 Ign. switches later
). Anyhow, Now I have nothing as far as title says. Tested plug for PCM, have no power there. Kinda lost on what to do from there. Dont want to chase things around if I do not to. Any help would be greatly appreciated. Thanks!
To clarify, I tested the PCM plug as per the sticky. I have no power at cavity 3 with key off. Nor do I have power at cavity 9 with key on. So I am assuming something is not letting power to the PCM plug. Dont know too much about electrical on autos. Have fixed 1 fusible link to wire #1 on ignition switch ayesterday when I put the new switch in. Need to know where power comes from for PCM plug. Thanks!
Checked the harness by the fuel filter, didnt find anything out. Ran out of daylight while looking for the fusible link for #3 cavity. any pointers on where the fusible link is for #3 cavity. Harness still has all the factory loom and tape on it. Or do I just need to open the harness up. Thanks once again!
Update, Found the fusible link that supplied power to PCM plug, patched it back into another feed and Voila! success
Dont know why they run it all that way, Guess so when we try to work on things we just want to
:. Anyhow, Thanks for all your help. Wanna, you seem to be some kind of 1st Gen Guru!!!! Sorry my 1st post had to be a problem, Hopefully I wont have to ask for too much help in the future. Once again THANKS!!!!
You could give me a wiring diagram and I would just be more confused! Lol! As I said I am not that savvy at wiring, but I am learning, (Guess I have too if I keep driving a 1st Gen,) Love my truck but some things they designed leave alot to be desired
Thanks again for all your help!!!
thewished
Jan 29, 2008 02:38 PM
ajohnson007
Dec 15, 2005 07:37 PM
