New Radiator
Old Oct 26, 2009 | 06:49 AM
squarenose's Avatar
New Radiator
Well, had some bad luck this weekend. The fan shrowd came off and got into the fan and bent the fan blade and then the bent fan blade sliced a hole into my radiator. Should I get a bigger better Radiator? And Where could I find one with out having to do to many mods?
Thanks in Advance!
Old Oct 26, 2009 | 09:14 AM
patdaly's Avatar
Don't know specifically about a first gen, but I can say the second gen radiator is plenty big........ I would say the first gen probably would be as well.
Old Oct 26, 2009 | 10:48 AM
maybe368's Avatar
When I replaced mine, I first took it to a radiator shop that I have used for years and that I trust completely and they told me that they could not re-core it because it is a special ultra high surface area core. He returned my radiator and did not charge me a dime, so I tend to believe him . I found a new one for around 300 bones...Mark
Old Oct 26, 2009 | 11:03 AM
ppiggppenn's Avatar
Thanks in Advance!
A new rad cost is rarely wasted if the old one was 10+ years old. Now'd be a good time to trash the old fan too and go electric. I saved fuel with mine, and it's a lot safer place when I'm in there with it idling.
Old Oct 27, 2009 | 08:24 AM
sooty's Avatar
rad
your later first gen already uses a larger radiator, but i see your in a hotter area, as am i, i had the core replaced with an mx tube configuration, that flows through crimps, to transfer more heat, they use it in nascar, i also upgraded to 3 rows, from 2, by spreading the tanks out a little, another note, any more than 18 fins per inch, will restrict air flow, some builders will go to 22 f.p.i., hope that helps.
8liter
Sep 22, 2012 10:19 AM
jiMMyCTD
May 30, 2005 10:12 AM
Mcmopar
Mar 16, 2005 02:05 PM
awmasparky
Jul 19, 2003 10:41 PM
