New owner = Questions
Old Jul 24, 2007 | 02:45 PM
max924's Avatar
Hi everyone, I am the proud new owner of a 1991.5 W250 5spd and have some questions:
1 -- Looking to get some manuals so I can work on the darn thing. I have read that some get the manual for the '93 since it has the getrag rebuild, will my '91 differ enough to matter if I do get a '93 (I don't want to have too much misinformation just to have a rebuild for the 5 spd.) I figure I will just get one from geno's.
2 -- The bottom of my fuel filter in the engine bay has a sensor that is not connected ( wires appear torn out) would this be the "water in fuel" sensor, and should it be fixed asap?
3 -- My front springs are almost on the bump stops and I am looking for a good stock replacement for all four springs, any ideas? I am not looking for any real lift.
4 -- The previous owner had turned the pump up but I don't know where to start with the injection pump to fool around with it. Are there any particularly good resources to learn about it (like diagrams and all that).
5 -- Last question for now, I am looking at getting a Stan's complete 4" exhaust system, is this a tried and true setup and is it mandrel bent.
I'll appreciate any help you guys can give me,
Max
Old Jul 24, 2007 | 03:02 PM
RumbleFish's Avatar
1--The 93 manual will work fine. For over the minor differences, ask away on here.
2--Yes it is. It might not be importnant enought to stop driving it right now, but its a pretty good idea to get it fixed at the earliest opportunity.
3--Superlift 2.5" front springs ride a ton nicer than the stock units, and will give you a nice level appearance.
4-- http://dodgeram.org/tech/dsl/more_power/Power_ve.htm
just be sure to put egt and boost gauges before you mess with it too much
5 will have to wait for somebody else.
If the trans is the stock getrag, make sure to overfill the it by at least 1 qt. Alot of people like synthetic 5w30. You'll need 4.5 qts minimum, but I'd go ahead and dump in all 5.
Old Jul 24, 2007 | 03:04 PM
leper's Avatar
Welcome to the site!
I am awaiting the answer on the Stans also. I will probably do it next month(pay providing) and I will be using their downpipe as well.
Old Jul 24, 2007 | 06:59 PM
I would suggest getting the '91 FSM, especially if the truck is non-intercooled. There are significant wiring differences - and the wiring diagrams are one of the most useful things in the FSM. There are several guys on DTR who will email you a pdf of the Getrag rebuild section.
Buy a WIF sensor and change it whenever you get around to changing the filter. It's not critical.
Stan seems to get good reviews.
Old Jul 24, 2007 | 07:07 PM
BearKiller's Avatar
Or just throw it away and use Fleetgaurd FS1221 solid-bottom water-seperating fuel-filters; they are about twice as large as the little stock ones and you never have to mess with the seperate bottom piece again, just spin on and go.
Well ----- maybe don't completely throw it away, just lay it back for unseen emergencies.
Old Jul 24, 2007 | 08:56 PM
max924's Avatar
Thanks for the replies, who would have thought strangers on the net could have been so helpful!
My truck is intercooled and the electrical was the main reason I was wondering about the different years for manuals. I know how a good set of electrical diagrams can make or break successful troubleshooting.
I guess there is no way of knowing the stock settings for my pump since I didn't adjust it? Maybe I'll just turn it down to lessen the smoke and keep my EGT's in check till I am ready to do some real tuning (see pyro, 4" exh., and BHAF)
Max
Old Jul 24, 2007 | 11:18 PM
leper's Avatar
If the guy doing the adjusting was worth his salt, he marked the original settings with a scribe or marker or chainsaw or something.
Old Jul 25, 2007 | 04:22 PM
'91.5 diagrams are hard to get. The '91 FSM shows the non intercooled style wiring.
The '91.5 trucks used a different PCM than the '92 and '93 trucks, so the wiring under the hood is different. The '91's didn't have a PCM.
Old Jul 28, 2007 | 10:54 AM
max924's Avatar
So where can I attain 91.5 electrical diagrams? Maybe I will just get a '93 manual since the electrical is that different between '91 and '91.5
Old Jul 28, 2007 | 11:21 AM
That's a hard one. Maybe someone with a '91.5 who as gotten accurate diagrams will speak up...
Old Jul 28, 2007 | 03:23 PM
Ace's Avatar
Ace
Here ya go:
http://72.19.150.167/PhotoAlbum/Cars...l_Diagrams.zip
truckroc
Introductions / New People
Jun 10, 2017 02:57 AM
92GhostRyder
Aug 11, 2010 08:31 AM
st_pinetree
24
Feb 6, 2004 05:17 PM
RacerDude
Dec 31, 2003 09:34 AM
bulabula
Oct 30, 2002 05:53 PM
