New to Diesels
Old Nov 1, 2014 | 06:52 PM
Redtruck-VA's Avatar
New to Diesels
Picked up this 1989 D250 last weekend. It's my first diesel so I'm on a steep learning curve. Doing the odds and end things to make it road ready. Current project is replacing the passenger side UCA ball joint and knuckle. It had the ball joint welded in and it is destroyed along with being loose in the spindle, ruining the upper mounting hole. Should have all the parts in hand Wednesday. I'm really liking this old girl...
Old Nov 1, 2014 | 07:09 PM
crazzywolfie's Avatar
welcome lol. don't forget to check out the FAQ/Knowledge base "How do I...?" Look here first! A.K.A. "The Sticky" thread. it is full of lots of info that is fairly organized. i was thinking about posting a link to it the other day for you but i have got in enough trouble on that forum for posting links to other forums lol
Old Nov 1, 2014 | 07:14 PM
mknittle's Avatar
Looks like a good project.
Old Nov 1, 2014 | 08:16 PM
I'm reading through the threads now. Tons of great information to be found.
Thanks,
Old Nov 1, 2014 | 10:00 PM
Welcome to the board, and the 1st Gen diesel family. I was in your exact shoes about 4 years ago now....Yes it is a steep learning curve, but worth all the time you will put into learning how to work on these old trucks.
Looks like a nice project you have there. Personally I would loose that K&N style air cleaner...they are junk, in my experience and opinion. Better off to run a BHAF (Big Honking Air Filter) if you need more air flow. Check out the Sticky on how to fabricate and install one.
Old Nov 2, 2014 | 07:15 AM
I agree with replacing the K&N, I'm ordering up pieces today. Contacted a guy to put together the complete OEM filter setup and haven't heard back from him. I think I'll use a OEM type filter in it's original location and just make a tube to the turbo. OEM I saw flows something like 450 cfm, I would prefer something that flowed twice that. Appreciate the input,
Thanks
Old Nov 2, 2014 | 07:40 AM
mknittle's Avatar
It is pretty easy to put together a bigger intake. All you need is a bibber air filter ( BHAF) some aluminum tube and some of these.
http://www.siliconeintakes.com/turbo...91ff83c5581681
Old Nov 2, 2014 | 07:52 AM
Thanks for the link. Is the BHAF a specific design or just a reference to big tube intakes? Any recommendations on filters?
Thanks,
Old Nov 2, 2014 | 08:32 AM
mknittle's Avatar
Thanks,
It is an abbreviation of Big Honkin Air Filter.
here is a thread that may be of interest.
https://www.dieseltruckresource.com/...highlight=Bhaf
And one with part numbers.
Old Nov 2, 2014 | 08:52 AM
Thanks, did some searching and found a some threads, I like the soup pan.. The filter has gone up some from the prices quoted but looks like it would certainly provide air... another project....
Old Nov 2, 2014 | 06:05 PM
mknittle's Avatar
there are some pretty inventive people around here.
Old Nov 2, 2014 | 06:13 PM
I can see that, very impressive. How are folks setting up gauge on a 1st gen?
Old Nov 2, 2014 | 06:55 PM
mknittle's Avatar
Which one?
Old Nov 2, 2014 | 07:10 PM
Which one?
89' specifically, if that is what you mean. Gauge wise, I would like Boost, EGT and fuel pressure. A Tach I put probably on the steering column.
Old Nov 2, 2014 | 08:59 PM
I see some tachs have a mag pickup using the flywheel. Anyone know the number of teeth on the Cummins flexplate (727)?
