New to Cummins charging issues?
Still no charge guys. I was reading some stickies and found out that I can switch the ac relay, or starter relay to test the asd? But how do I properly check the cps? I don't want to have to buy a new cps or pcm.. also read that if the ac is working that the pcm is fine? Need some help really want to get this charging issue under control. Put in a new alternator and battery and changed out the battery terminals as they needed replacing. Also put in a new belt and tensioner. What should I test next? Grid heaters are not coming on. I have an aftermarket cylinder key lock didn't get to put the stock one in yet. But this charging issue is driving me crazy.
Check the large terminal on the alternator. It should be at battery voltage at all times or the 150 amp fusible link is blown.
Check the field terminals. One is held positive by the ASD circuit, and the other is driven to ground by the PCM. If both are at ground, the ASC circuit is faulty. If both are at battery, the PCM branch has a hole in it somewhere. The diagrams are in the stickies.
You can lose one branch of the PCM and not another. You really have to get serious about trouble shooting, or employ someone who can or you will waste more money on unneeded parts.
Diesel-Dan
20
Sep 22, 2019 09:34 PM
GLHS
Feb 25, 2011 10:12 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
